on 14-01-2022 20:46
After a week with my Hub5 router I have lost connection via all the devices connected via wireless.
The devices can see the router but have no internet access and are unable to connect to router (192.168.0.1)
Wired connections are still fine so it shouldn't be broadband issues.
Should I revert back to me old router?
Thanks for any suggestions
David
on 14-01-2022 20:59
@davidallan wrote:After a week with my Hub5 router I have lost connection via all the devices connected via wireless.
David
Yes
on 14-01-2022 21:14
Thanks for the help.
Reverting back to the old hub didn't work - I assume due to the different settings required at VirginMedia's end to communicate with the hub.
I have reverted back to the Hub5 so that I can at least have a wired connection.
Regards, David
on 14-01-2022 21:26
@davidallan wrote:Thanks for the help.
Regards, David
They’ll likely need to activate the old hub.
Or, you bite the bullet and put the Hub5 into modem mode and get your own wireless router or mesh system. Which should have been done with the atrocious Hub3 really.
on 14-01-2022 22:33
