on 19-04-2022 11:56
Received new Hub5, installed with no other problems but my Kindle rejects the (unchanged) passphrase and hence won't connect to wifi. Any reason, any fix?
on 21-04-2022 13:16
Hi Alan9377,
Thanks for posting and welcome to our community 🙂
Sorry to hear you're having some issues with your Kindle connecting to your WiFi.
Have you tried a pin-hole reset of the hub and attempting to connect with the Kindle again?
Alex_Rm
on 21-04-2022 13:46
Try deleting the WiFi connection on the Kindle and re-creating it.
on 22-04-2022 07:34
Thank you both for this. As a result of these hints the problem has been solved by a soft reset of my Kindle. Perhaps it retained some vague memory of the previous hub even when it was no longer here..
on 25-04-2022 13:01
We're glad to hear that is sorted for you now Alan9377.
^Martin
