on 24-07-2022 00:52
Hello community,
Unfortunately I have been having multiple issues since upgrading to the Hub 5 + the powerline adapter/wifi boost combo. The biggest concern is the constant disconnections I'm facing, especially on wireless devices such as phones but also on devices connected to the Ethernet such as my computers.
This has been very frustrating to deal with especially when trying to work from home or watching media and then having it restart due to disconnections. Looking forward to a solution, thank you!
1 | 259000000 | 4.2 | 41 | QAM 256 | 16 |
2 | 139000000 | 4.2 | 41 | QAM 256 | 1 |
3 | 147000000 | 4.3 | 41 | QAM 256 | 2 |
4 | 155000000 | 4.3 | 42 | QAM 256 | 3 |
5 | 163000000 | 4.1 | 41 | QAM 256 | 4 |
6 | 171000000 | 3.7 | 42 | QAM 256 | 5 |
7 | 179000000 | 4 | 42 | QAM 256 | 6 |
8 | 187000000 | 3.6 | 42 | QAM 256 | 7 |
9 | 195000000 | 4.1 | 42 | QAM 256 | 8 |
10 | 203000000 | 3.6 | 41 | QAM 256 | 9 |
11 | 211000000 | 4.2 | 41 | QAM 256 | 10 |
12 | 219000000 | 3.8 | 41 | QAM 256 | 11 |
13 | 227000000 | 4 | 42 | QAM 256 | 12 |
14 | 235000000 | 4 | 41 | QAM 256 | 13 |
15 | 243000000 | 4.1 | 41 | QAM 256 | 14 |
16 | 251000000 | 4.1 | 41 | QAM 256 | 15 |
17 | 267000000 | 4.1 | 42 | QAM 256 | 17 |
18 | 275000000 | 4.1 | 42 | QAM 256 | 18 |
19 | 283000000 | 4 | 41 | QAM 256 | 19 |
20 | 291000000 | 3.9 | 41 | QAM 256 | 20 |
21 | 299000000 | 4.2 | 42 | QAM 256 | 21 |
22 | 307000000 | 3.7 | 42 | QAM 256 | 22 |
23 | 315000000 | 4 | 41 | QAM 256 | 23 |
24 | 323000000 | 3.9 | 41 | QAM 256 | 24 |
25 | 331000000 | 4.1 | 42 | QAM 256 | 25 |
26 | 339000000 | 4.3 | 41 | QAM 256 | 26 |
27 | 347000000 | 4.6 | 42 | QAM 256 | 27 |
28 | 355000000 | 4.4 | 42 | QAM 256 | 28 |
29 | 363000000 | 4.8 | 42 | QAM 256 | 29 |
30 | 371000000 | 5 | 42 | QAM 256 | 30 |
31 | 379000000 | 5 | 42 | QAM 256 | 31 |
1 | Locked | 41 | 0 | 9 |
2 | Locked | 41 | 29996 | 97719 |
3 | Locked | 41 | 30998 | 158867 |
4 | Locked | 42 | 29586 | 95309 |
5 | Locked | 41 | 9093 | 139367 |
6 | Locked | 42 | 353 | 78389 |
7 | Locked | 42 | 0 | 4504 |
8 | Locked | 42 | 0 | 16 |
9 | Locked | 42 | 0 | 20 |
10 | Locked | 41 | 0 | 36 |
11 | Locked | 41 | 0 | 27 |
12 | Locked | 41 | 0 | 33 |
13 | Locked | 42 | 1 | 77 |
14 | Locked | 41 | 0 | 53 |
15 | Locked | 41 | 0 | 46 |
16 | Locked | 41 | 0 | 19 |
17 | Locked | 42 | 0 | 8 |
18 | Locked | 42 | 0 | 6 |
19 | Locked | 41 | 0 | 6 |
20 | Locked | 41 | 0 | 1 |
21 | Locked | 42 | 0 | 13 |
22 | Locked | 42 | 0 | 10 |
23 | Locked | 41 | 0 | 11 |
24 | Locked | 41 | 0 | 5 |
25 | Locked | 42 | 0 | 8 |
26 | Locked | 41 | 0 | 10 |
27 | Locked | 42 | 0 | 8 |
28 | Locked | 42 | 0 | 3 |
29 | Locked | 42 | 0 | 1 |
30 | Locked | 42 | 0 | 2 |
31 | Locked | 42 | 0 | 1 |
1 | 60300000 | 47.8 | 5120 | QAM 64 | 9 |
2 | 53700000 | 48.3 | 5120 | QAM 64 | 10 |
3 | 46200000 | 48.3 | 5120 | QAM 64 | 11 |
4 | 39400000 | 47.8 | 5120 | QAM 64 | 12 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
23-07-2022 21:54:09 | warning | Dynamic Range Window violation |
23-07-2022 21:54:09 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-07-2022 18:48:49 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-07-2022 18:48:48 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-07-2022 18:37:16 | notice | CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: ; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-07-2022 18:37:11 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-07-2022 18:36:53 | warning | Unicast DSID PSN startup error |
23-07-2022 18:36:45 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
23-07-2022 18:36:39 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-07-2022 18:36:34 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-07-2022 18:36:31 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-07-2022 18:36:28 | notice | Honoring MDD; IP provisioning mode = IPv4 |
17-07-2022 22:34:37 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 22:34:32 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 22:32:17 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:48:41 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:48:41 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:48:41 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:48:21 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:48:21 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:48:21 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:48:01 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:48:01 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:46:42 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:45:55 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:45:52 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:45:47 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:29:24 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:16:54 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:16:49 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 21:16:39 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-07-2022 20:25:04 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 24-07-2022 12:05
Lots of post RS errors and also T3 timeout errors.
Check for local issues on 0800 561 0061 and ensure that all cables and connections are tight and secure and not kinked or damaged.
Also try a 30 second pinhole reset of the hub with no ethernet connection.
on 24-07-2022 14:47
on 24-07-2022 15:19
"Put hub in modem mode and get a better WiFi router with 1Gb ports"
This will NOT fix the obvious circuit problem. Possibly it’s noise ingress, you need to check for local issue and if none contact VM.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page http://www.virginmedia.com/servicechecker although this only covers large outages.
VM will not dispatch any technicians while an area fault exists.
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 26-07-2022 15:36
Hello jackboland, thank you for reaching out and I am sorry to hear about your recent connection issues.
I have a taken a look at our side and I cannot see any major issues, however I would like to run some tests with you.
I am going to send you a PM, please keep an eye out for the purple envelope. Thanks
Matt - Forum Team
New around here?
