Anne140
  • 10
Message 1 of 7
Hub4
My wifi has never been so good since getting this hub4 but cannot whatsoever connect my ring doorbell please no techy answers if you have any idea please make them as simple as possible
thanks In advance
Sasha_W
  • 973
  • 40
  • 75
Message 2 of 7
Re: Hub4
Hi @Anne140
Thanks for posting this back on here 🙂
Sorry to hear you're having issues with your hub 4, I will try to make this as easy as possible for you. 🙂
Does the hub box show up on the ring doorbell app when you search for it?
Is the ring doorbell the only device you are having issues connecting to the hub with?
How is the ring doorbell connected up? Is it wired or wirelessly?
Please do let me know.
Sasha - Forum Team
Anne140
  • 10
Message 3 of 7
Re: Hub4
Hi Sarah
yes it does show up on the ring app and it is connected wirelessly
Sasha_W
  • 973
  • 40
  • 75
Message 4 of 7
Re: Hub4
Thanks for replying back to me @Anne140
What happens when you click the hub on the ring app? Does it just not connect or does it connect but drop off straight away?
May sound a bit silly, but have you carried out a pin hole reset on the hub to see if this works?
At the back of the hub there should be a small hole, with something pointy, press it down for 10-15 seconds, then wait 10 minutes for it to load up.
Could you let me know if it then lets you reconnect to the ring doorbell?
Sasha - Forum Team
Anne140
  • 10
Message 5 of 7
Re: Hub4
Thank you Sarah, yes I’ve reset everything it just doesn’t connect whatsoever even though it shows
Paulina_Z
  • 514
  • 16
  • 33
Message 6 of 7
Re: Hub4
Hi @Anne140,
Thank you for getting back to us!
I'm sorry to hear that you're still having connection issues. Can you tell us if you've reset your ring doorbell as well?
If this is the only device that seems to be impacted and not connecting to the network, have you been in touch with the company that provides the ring doorbells, to see if there's some troubleshooting available?
Please keep us updated on this if you can.
Paulina_Z
Anne140
  • 10
Message 7 of 7
Re: Hub4
Yes I reset everything, contacted ring and they are sending a new one🙈 just hope it works, strange though it only stopped when I got the hub 4 will keep you posted when I receive the new one 🙏🏻
