on 25-08-2022 03:56
Recently got a Hub4 but still only getting 350 meg, not the 1 gig update as promised. Connected with Cat 6, PC reports 1 gig LAN speed. Also, this thing reboots itself every night between 3 and 4 a.m. - Should this be happening?
on 28-08-2022 12:50
Hi pbraham,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue with your broadband speed.
I am more than happy to take a look into this for you.
I will private message you to confirm your details and take a look into this.
^Martin
on 29-08-2022 04:54
Post your Config File from the HUB GUI in this thread.
on 29-08-2022 11:03
cmreg-vmdg640-bbt076-b.cm
on 29-08-2022 11:20
I’m on 1G and have the same config file.
on 29-08-2022 14:59
I meant the stats from the Config page sorry
It will be tables of numbers.
on 29-08-2022 15:43
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | cmreg-vmdg640-bbt076-b.cm |
SFID | 2562 |
Max Traffic Rate | 1200000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 2561 |
Max Traffic Rate | 55000270 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
on 29-08-2022 19:20
Looks ok for 1Gb/s but my DL reads slightly different as it is: 1230000450
on 29-08-2022 22:35
I suspect they haven't removed the cap at their end.
on 01-09-2022 15:29
Hi @pbraham,
Thank you for coming back to us. I can see that my colleague has reached back out to you via Private Message to have this issue looked into. Please get back to them as soon as you can so that we can help investigate this issue further for you.
Thank you.
