on 17-12-2021 18:34
So I've taken the plunge and upgraded to 1gig and already have the superhub 5. I was advised that I actually needed a superhub 4 for the 1 gig package...is this correct? It seems very odd...
on 17-12-2021 18:38
on 17-12-2021 18:44
on 17-12-2021 18:53
I don't have any pods (I assume this is for the WiFi)?
So should be ok with the Hub5 then?
on 17-12-2021 19:12
@seanbootes Yes you should be Ok, the issue would be that as a Gig One subscriber, you would be eligible for free wifi pod, which as they don’t work with the Hub 5 could be slightly embarrassing. Also if you happen to have the VM phone service where the phone plugs into the hub, well that doesn’t work either!
on 17-12-2021 19:30
Considering the hub5 was made for the 2GB connection I would say it would work with a 1GB connection…
on 20-12-2021 12:54
Hi seanbootes,
Thanks for your post and reaching out to us. Just to confirm what everyone else has replied, the Hub5 will work great with the 1GB service. The hub 4 might have been mentioned because the hub 5 hasn't been fully released yet.
Cheers,
Corey C
on 20-12-2021 16:10
@seanbootes Read the forum, and there's a lot of teething problems with the Hub 5. You might not encounter them, but in your shoes I'd be happily welcoming a Hub 4 and sending the Hub 5 back. But hopefully you can make an informed choice - do you want to be an early adopter of the Hub 5, working with unproven technology that usually takes a couple of years for most of the flaws to be ironed out? That can be a valid choice if it works for you.
