Settling in
Message 1 of 7
Hub4-home network has a few problems
Symptoms- if on a whatsap video call keep dropping out of call with "call reconnecting" message and beeps. Sometimes re-connects , sometimes doesn't. This happens even if within 2 feet of the hub
Network diagnostic check- have run this through the router. It says "your home network has a few problems" but no suggestion of what and how to fix
How do you actually get Virgin to fix this??
mike
  • 12.3K
  • 952
  • 1.58K
Message 2 of 7
Re: Hub4-home network has a few problems
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Settling in
Message 3 of 7
No problem on ethernet connection and diagnostics says no problem
Settling in
Message 4 of 7
no problem on ethernet connection
  • 25.21K
  • 1.45K
  • 3.21K
Message 5 of 7
Are all wireless devices experiencing issues?
Settling in
Message 6 of 7
Because these are Whatsap video calls these only apply to mobile phone calls
Zoom calls on ipad are ok.
But..if network diagnostics says "your home network has some problems" it would suggest that that it's the network rather than a specific device?
  • 25.21K
  • 1.45K
  • 3.21K
Message 7 of 7
No, that's the hub trying to be smart (which it's anything but).
