on 26-11-2022 12:33
Since switching to Hub4 months ago, internet has been poor with lost wifi connections etc.
In the latest attempt to improve wifi matters by process of elimination, this morning, a friend from a networking company came round to set up his own Ubiquiti Dream Router. When it was plugged into the yellow ethernet ports on the Hub4, the Ubiquiti router display showed 'No internet detected'. We tried different cables and tried all four ports - but still 'No internet detected'.
Unless anyone in this community has any other ideas to try, I'm guessing we need a replacement Hub4?
Any thoughts?
on 26-11-2022 12:45
What do the LEDs show on the port that is being used? You could try a pin hole reset of the hub, it has been known to fix this type of problem.
on 26-11-2022 20:13
"What do the LEDs show on the port that is being used?" - sorry to be a bit naive, but where are the LEDs? If you mean the ethernet port on the back of the Hub4, there are no lights at all. I think I'm probably misunderstanding you. Here's how it's set up ...
on 26-11-2022 20:49
Cannot see the back of my hub5 as it’s under the floor. Most devices have a green & yellow LED on the socket, but maybe VM are cutting costs yet again. I’m not sure about the picture of the UDM, possibly a LED each side of the socket, my UDM-Pro certainly has LEDs on all its sockets.
