on 10-10-2022 12:09
Hi there, i am having the exact same issue, and this is affecting my business and work calls for me and my wife. I have tried resetting the box multiple times, but my WiFi still cuts out every 10 minutes or so in online calls. Please help!
on 12-10-2022 14:35
Hi tuck411,
thanks for your post and I'm very sorry to hear you're having some issues with your Hub displaying a red light.
Just to double check, is the Hub currently in modem mode? If so then the light will be a magenta colour but can look quite red. This is perfectly normal. I know you've already mentioned you've done a reboot however if the hub is not in modem mode then please follow the below steps:
If the issue remains, we'll need to arrange for an engineer to visit to swap out the Hub. To avoid any delay I've sent you a private message to confirm your address. If the light does return to normal then you can ignore the PM.
