on 24-09-2022 15:35
Hi there,
I recently moved into my new property, and had my Hub3 transferred, and my connection upgraded to a 500Mbps contract (and have Volt as well)
I do have some weaker spots in the WiFi, and want to try out using some WiFi pods to see whether it will resolve the issue?
Is this still a case of phoning customer support to order 2 of these pods?
Thanks in advance!
on 24-09-2022 15:58
on 26-09-2022 16:33
Hello nick67.
Thanks for your first post and welcome to our Community.
Sorry to hear you are having an issue with Wi-Fi coverage.
I can assure you as a Volt Customer, you can have a maximum of 3 pods free.
We can only send one out at a time.
I'd like to take a look into this for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
