on 28-01-2021 18:34
Despite rebooting several times this error is always returned when conducting the diagnostics. Despite ethernet connection to router continually receive weak signal strength when on Teams/Skype or Zoom. Can't get through to VM CS so can someone please throw some light on what to do to resolve - even if that means buying other Router/MESH equipment.
Logs from Router below:
Acquired Downstream Channel (Hz) | 331000000 | Locked |
Ranged Upstream Channel (Hz) | 46200000 | Locked |
Provisioning State | Online |
1 | 331000000 | 6.6 | 38 | 256 qam | 25 |
2 | 203000000 | 5.1 | 38 | 256 qam | 9 |
3 | 211000000 | 5 | 38 | 256 qam | 10 |
4 | 219000000 | 5 | 38 | 256 qam | 11 |
5 | 227000000 | 4.9 | 38 | 256 qam | 12 |
6 | 235000000 | 5 | 38 | 256 qam | 13 |
7 | 243000000 | 5 | 38 | 256 qam | 14 |
8 | 251000000 | 5 | 38 | 256 qam | 15 |
9 | 259000000 | 5 | 38 | 256 qam | 16 |
10 | 267000000 | 5.1 | 38 | 256 qam | 17 |
11 | 275000000 | 5.3 | 38 | 256 qam | 18 |
12 | 283000000 | 5.5 | 38 | 256 qam | 19 |
13 | 291000000 | 5.8 | 38 | 256 qam | 20 |
14 | 299000000 | 6.1 | 38 | 256 qam | 21 |
15 | 307000000 | 6.1 | 38 | 256 qam | 22 |
16 | 315000000 | 6.5 | 38 | 256 qam | 23 |
17 | 323000000 | 6.3 | 38 | 256 qam | 24 |
18 | 371000000 | 6.8 | 40 | 256 qam | 26 |
19 | 379000000 | 6.9 | 38 | 256 qam | 27 |
20 | 387000000 | 6.4 | 40 | 256 qam | 28 |
21 | 395000000 | 6.5 | 40 | 256 qam | 29 |
22 | 403000000 | 6.5 | 40 | 256 qam | 30 |
23 | 411000000 | 6.8 | 38 | 256 qam | 31 |
24 | 419000000 | 6.8 | 38 | 256 qam | 32 |
1 | Locked | 38.9 | 249 | 0 |
2 | Locked | 38.9 | 147 | 0 |
3 | Locked | 38.6 | 142 | 0 |
4 | Locked | 38.9 | 139 | 0 |
5 | Locked | 38.6 | 170 | 0 |
6 | Locked | 38.6 | 159 | 0 |
7 | Locked | 38.6 | 191 | 0 |
8 | Locked | 38.6 | 219 | 0 |
9 | Locked | 38.6 | 186 | 0 |
10 | Locked | 38.9 | 207 | 0 |
11 | Locked | 38.6 | 190 | 0 |
12 | Locked | 38.9 | 232 | 0 |
13 | Locked | 38.6 | 245 | 0 |
14 | Locked | 38.6 | 279 | 0 |
15 | Locked | 38.6 | 297 | 0 |
16 | Locked | 38.6 | 287 | 0 |
17 | Locked | 38.9 | 346 | 0 |
18 | Locked | 40.3 | 288 | 0 |
19 | Locked | 38.9 | 384 | 0 |
20 | Locked | 40.3 | 390 | 0 |
21 | Locked | 40.3 | 489 | 13 |
22 | Locked | 40.3 | 476 | 0 |
23 | Locked | 38.9 | 495 | 0 |
24 | Locked | 38.6 | 552 | 0 |
1 | 46200000 | 42 | 5120 | 64 qam | 1 |
2 | 25800000 | 39.5 | 5120 | 64 qam | 4 |
3 | 32600000 | 40 | 5120 | 64 qam | 3 |
4 | 39400000 | 40.5 | 5120 | 64 qam | 2 |
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1 | ATDMA | 0 | 0 | 19 | 0 |
2 | ATDMA | 0 | 0 | 31 | 0 |
3 | ATDMA | 0 | 0 | 5 | 0 |
4 | ATDMA | 0 | 0 | 2 | 0 |
Answered! Go to Answer
on 13-02-2021 10:48
Hi Chris_W1 (VM Forum team,
Given current performance issues no better than before - see below
I assume the expected fix (F008756539) on the 11-Feb has not been completed as expected. Could you kindly give an update as to when this will be resolved please?
Many thanks
on 13-02-2021 10:52
And same usual response when running router/Hub3 diagnostics at 10:50 this morning (13-Feb) !?!?
on 16-02-2021 09:28
VM Forum - please can you advise when fault reference F008756539 is now estimated to be fixed as quite clearly it was not as predicted on the 11-Feb.
Is there a way to check myself by entering this fault reference somewhere else?
on 11-05-2021 10:31
Hi @YabbaDabbaDo,
I'm sorry but I have bad news the SNR issue has been fixed but the original ticket F008756539 is still active and the estimated resolution date is back to 2nd August.
Regards,
Steven_L
on 11-05-2021 10:41
on 13-05-2021 11:18
Well that is great news!?!? SNR has solved little/nothing and the congestion issue in existence within the Ipswich area for ages now is not forecast to be fixed until August. I guess what that translates as "put up with patchy service until the congestion issue is addressed by F008756539 but that date will keep going back and back. But we'll still charge you the same regardless"
I have no idea how complicated it maybe to fix a congestion issue but I can tell you how annoying it is to be on the other end of such!!
lotharmat - lucky you 🙂
on 13-05-2021 11:30
We can appreciate the frustration this ma cause you YabbaDabbaDo.
We will do all we can to have this resolved for you as soon as possible
Kindest regards,
David_Bn
on 13-05-2021 12:09
Heard it all before. VM really!?!
on 13-05-2021 12:16
@YabbaDabbaDo Given the circumstances, would you want to leave VM and move to another ISP?
on 13-05-2021 18:44
Andrew_G
I have been with VM for years, which might be the problem, and have never had any issues until lockdown, but with nothing changing my end, other than working remotely with a wired connection, it has taken an absolute nose dive as the BQM pictures portray!
I wouldn't mind if there was:
a) any certainty that the delay date were ever to materialise (albeit some 3 months away)
b) any confidence that when/if it does get stated as completed this would be noticeable from my end
c) the option to buy additional equipment (not sure what?) and switching the Hub3 into modem mode may resolve the issue without a) or b); or
d) change ISP provider as you suggest - any recommendation?
