on 24-01-2023 18:15
Since last Friday our broadband has been troublesome, in particular the upload speed has dropped considerably which means our son cannot live stream - downstream is ~350Mbs, upstream varies between ~0 & 2Mbs.
So I rebooted our Hub3 and ever since our WiFi keeps cutting out. When it does cut out there are no WiFi connections showing from our router at all. Then after a minute or two, all WiFi connections appear again and our devices reconnect. Not sure if this is a problem with the Hub3?
I also checked on the VM website which shows there are known issues with our postcode area, so not sure if it's all connected?
Answered! Go to Answer
on 30-01-2023 17:35
Our speed seems to have resolved after the recent nt outage / work in our area.
on 24-01-2023 19:39
You cannot do anything until the area fault is fixed.
on 26-01-2023 20:16
Hi PhallCurryLover, thanks for the message and welcome to the forums.
I can see that there is an outage in the area under fault - F010411401 and this is estimated to be resolved on the 2nd Feburary.
KInd regards Chris.
on 30-01-2023 17:35
on 30-01-2023 21:35
on 02-02-2023 12:25
Thanks for the update @PhallCurryLover, and I'm pleased to hear the services have since improved with the fixing of the issue in the local area.
Do feel free to keep us updated on any further faults you experience.
Kindest regards,
David_Bn
