  • 24
sinky
Message 1 of 7
Hub3 WIFI Issue
WIFI speed keeps dropping to less than 2Mbps. When I reboot the hub it goes back up to greater than 60 Mbps for a few minutes and then drops again. This is all done standing next to the hub.
In parallel my wired PC is consistently getting 200 Mbps.
I have rebooted hub 3 times this evening and get the same behaviour.
New hub needed ?
  • 2.05K
  • 71
  • 138
Message 2 of 7
Re: Hub3 WIFI Issue
Hi sinky,
Thanks for posting. My apologies for the low speeds.
We do need an engineer visit from running a check in your area.
I'll go ahead and send you a PM to arrange this now.
Kind regards,
John_GS
  • 3.1K
  • 172
  • 498
chenks
Wise owl
Message 3 of 7
Re: Hub3 WIFI Issue
why would an enginer visit be required for what appears to be just a WIFI issue?
the OP said that ethernet connected speeds are at 200Mbps.
  • 2.05K
  • 71
  • 138
Message 4 of 7
Re: Hub3 WIFI Issue
Hello chenks,
This would be due to checks ran in the background and following resolution of said checks ran, but thanks for your comments and I hope you're having a fabulous weekend Smiley Happy
Kind regards,
John_GS
  • 3.1K
  • 172
  • 498
chenks
Wise owl
Message 5 of 7
Re: Hub3 WIFI Issue
care to elaborate on the checks? and what the engineer will be doing on the visit?
if it's simply to replace the hub then surely you don't need to send someone out to do that - simply send it out in the post.
was is the fault that the check came up with? a fault that would only affect WIFI connectivity and not ethernet?
  • 12.35K
  • 466
  • 1.1K
Message 6 of 7
Re: Hub3 WIFI Issue
Likely to do with power levels but if the OP is getting 200 Mbps by wire its doubtful fixing power levels would fix WIFI or maybe a hub change might fix that.
  • 3.1K
  • 172
  • 498
chenks
Wise owl
Message 7 of 7
Re: Hub3 WIFI Issue
exactly, i'm struggling to think of what checks were done that showed a problem that only affected WIFI.
