on 04-01-2023 15:00
Hello
My Hub 3 router has a constant red light on and is only giving intermitent wifi.
I have tried turning the router on and off.
I have tried resetting it for 30 seconds with a pin.
None of this has worked.
Please advise what can be done to help this situation as I work at home it is essential i have wifi.
Many thanks
on 04-01-2023 15:52
Hi there SAStucke,
Thanks for your post and a warm welcome to the community.
Sorry to see that your Hub is experiencing problems.
This may need replacing, so we can investigate it further I've dropped you a PM.
The message can be found within the purple envelope icon.
Regards,
