First reset the Hub so you can login - as per below
________________
With the Hub switched "on", disconnect any ethernet connections (leave the co-ax connected) and then push in the “reset pin” with the end of a paperclip/thin nail/SIM tray “tool” or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT manually restart the Hub at any time. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card.
Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub they are different !
See if that sorts it.
Once you are logged in - try this
__________________________
Type in
http://192.168.0.1 into your web browser’s url box and login with settings password on the Hub's base sticker (or your own if you changed it). Then in Advanced>wireless>smart wifi - tick the disable “channel optimisation” box and save settings. Then, go to advanced>wireless>security, rename the 2.4 & 5 GHz network ssid's. Just change 'em to whatever you like and something that will differentiate them (e.g - xxxxx_2 & xxxxx_5) -- use the same password for simplicity, Then, apply settings and restart the Hub. Your 2 wifi networks will now be clearly separated - and you can then select the network you want to connect to individually from the "available networks" list on each device.
Note all your wifi devices will need re-connecting to the new SSID's and passwords.
5 GHz is always better/faster and subject to less interference (and is better for iDevices ) than the 2.4 one - although the 2.4 one has the better "range" and some older/cheaper/dumber devices can only use this one.
You should also use a wifi analyser App to check which 2.4 channels are being heavily used around you and move yours to one of numbers 1,6,11 that is least so, but it wont help if there is other interference.
See if these changes help - you will lose any “seamless roaming” benefits but it may not matter and you can always change the settings back by doing a " pinhole factory reset " if you prefer the way it was - or it doesn’t help.
