on 04-05-2023 19:41
My Hub3.0 arrived today. I make sure all the cable is properly connected. And then waiting over 30 minutes. But still have not network connection from our Wi-Fi account VMxxxxxxx.
on 04-05-2023 19:49
Hi @Tobychoi
The equipment is usually pre-activated, however you might need to call 0800 953 9500 to activate the hub.
If so have your account and area number handy, and the hub serial number.
on 05-05-2023 10:29
Today, I tried to reset and installed again for Hub3.0. Unfortunately, it still have no network connection. And I make sure all cables are properly connected. I already call 08009539500, which can’t give me a right answer and useful help.
I
on 08-05-2023 09:54
Hi @Tobychoi,
Thank you for your posts and welcome to our community forums. We're here to help.
I'm so sorry to hear that you've been having some issues with your router recently. I'm unable to detect any faults on our systems that would explain this. How are things for you today? Any better?
on 08-05-2023 10:08
Connect your laptop to the Hub 3 via a network cable and then ...
1) see if the laptop has internet access via the network cable
2) see if the Hub 3 responds at http://192.168.0.1/ if it does scroll down and click Check router status
