on 04-06-2022 14:38
My wifi appears to be working, but the connection to my home in ST1 appears to have failed. Usual tests have resulted in no apparent local problems, and testing my hub failed to resolve the issue, saying my hub isn't connected properly. The house phone shows the line failure, too. Anyone else got this in my area?
Engineer booked for Tuesday
Answered! Go to Answer
04-06-2022 14:53 - edited 04-06-2022 15:25
I'm not sure what tests you have done but the number to check for local issues is 0800 561 0061.
on 04-06-2022 14:55
on 04-06-2022 15:12
@Anonymous wrote:I'm not sure what tests you have done but the number to check for local issues is 0800 561 006.
You are a 1 short on the phone number 😎
on 04-06-2022 15:25
Yup realised that to my horror having seen Roger's post. Noted ta 😊👍
on 04-06-2022 17:29
Thank you all for the replies, I have checked the number, no issues.
Done the pinhole push reset, the mains off and on reset, 3 or 4 times, and left the hub off for a couple of hours before trying the reboot again so it could cool (usually always on)
The wireless connection to devices works, the broadband doesn't, nor does my home phone (obv) TV unaffected.
on 04-06-2022 17:36
Check your cables and connections are tight and secure and not kinked or damaged.
Log in to your hub via 192.168.0.1 and copy all the tables from all of the tabs under Advanced Settings here. We can comment but the VM engineer coming on Tuesday will probably be the answer here.
on 04-06-2022 18:33
The link appears not to load at all, gets to about 10% then stops.
Thank you once more, disappointingly, I'll await the engineer and perhaps a replacement hub? No one appears to have compromised the cabling in any way.
on 04-06-2022 18:38
Are you using your own router? If so the address is 192.168.100.1
on 04-06-2022 18:44
No, its a Hub 4 (white led ring around it)
