jonnyb1990
Hub error
Ok, so.had a power cut (lasted less than 10 seconds,
Now hub won't work, TiVo box works but has error c133, WiFi doesn't connect and doesn't show my router (top one)Screenshot_20181014-183946.png
  • 7.96K
  • 823
  • 1.23K
Re: Hub error
Which hub do you have? Is it a Tivo & not a V6?  Is it just wifi thats gone or do ethernet cable connected devices drop out too ?
If you havent already done this...  Pull the plug on all boxes and wait 5'.   Swich the Hub back on and let it go through start up.  Then plug Tivo back in and let it start up.  See if that helps.  If not try a pinhole reset of the Hub.
jonnyb1990
Re: Hub error
Ok.so it's. Hub 3.0,
Did as you suggested, ended up with a pin hole reset, no improvement,
On start up, solid white, flashes in quick succession green the red, the back to solid white,
Thinking hardware error at this point
jonnyb1990
Re: Hub error
Ok so hardwired a laptop in, DNS isn't reponrespo
jonnyb1990
Re: Hub error
Hub hardware failure confirmated, unable to login to the hub, engineer coming out on Tuesday as it is, at least the phone is working now !
  • 5.7K
  • 438
  • 946
Hero
Re: Hub error
Have you checked with your neighbours who have VM? The power outage may have affected the street box, and your hub is ok.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
