on 13-12-2022 20:05
Hi everybody. I’ve been following the posts on the Hub 5 with great interest. Currently I use it in modem mode and feed directly into a Netgear R8000 router which handles all the wifi.
up till a few days ago - on 125 gbs worked fine on wifi signal around 30 feet away and through two walls. No wifi dropouts and stable steady signal
Now just updated to 250 gbs - strong signal near to router but 30 feet away signal level very variable and even a few dropouts.
it seems I’m seeing similar issues to others who are using the native wifi on the hub
Really puzzled on this one - almost seems if my modem (wi fi 5 and set to 2.4 and 5 ghz bands )is being choked by the extra level of data feed
I would be very interested in some advice on the forum to tell me where I am going wrong!
thanks in advance
Answered! Go to Answer
on 15-12-2022 09:43
As promised I have followed your suggestion. Reset Hub 5 using pin and put it back into Modem mode
Summary now as follows
Standard specification compliant
DOCSIS 3.1
Hardware version
1.1
Software version
LG-RDK_4.6.24-2206.7
Cable MAC address
Cable modem serial number
YAAS13586009
System up time
0day(s)18h:53m:27s
Network access
Allowed
INTERNET 252/26 - LAN connections solid in all cases with either plan
WIRELESS with 250gb plan
( 5ft no obstruction ) 5ghz 274/26 2.4 ghz 104/26
( 20ft -2 solid walls) 5ghz 208/26 2.4ghz 33/22
( 30 - 3 solid walls ) 5ghz 126/19 2.4ghz 17/16
WIRELESS with 125 Gb plan
( 5ft no obstruction ) 5ghz 130/15 2.4 ghz 90/14
( 20ft -2 solid walls) 5ghz 128/15 2.4ghz 60/14
( 30 - 3 solid walls ) 5ghz 90 /15 2.4ghz 50/14
1 330000000 5.9 41 QAM 256 25
2 202000000 5 41 QAM 256 9
3 210000000 5.2 41 QAM 256 10
4 218000000 5.3 41 QAM 256 11
5 226000000 5.2 41 QAM 256 12
6 234000000 5.3 41 QAM 256 13
7 242000000 5.3 41 QAM 256 14
8 250000000 5.3 41 QAM 256 15
9 258000000 5.4 41 QAM 256 16
10 266000000 5.5 41 QAM 256 17
11 274000000 5.5 41 QAM 256 18
12 282000000 5.5 41 QAM 256 19
13 290000000 5.7 41 QAM 256 20
14 298000000 5.7 41 QAM 256 21
15 306000000 5.9 41 QAM 256 22
16 314000000 5.9 41 QAM 256 23
17 322000000 5.9 41 QAM 256 24
18 338000000 6 41 QAM 256 26
19 346000000 6 41 QAM 256 27
20 354000000 6 42 QAM 256 28
0 49600000 51.8 5120 QAM 64 1
1 43100000 51.8 5120 QAM 64 2
2 36600000 51.8 5120 QAM 64 3
3 30100000 52 5120 QAM 64 4
4 23600000 51.3 5120 QAM 64 5
0 ATDMA 0 0 0 0
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access Allowed
Maximum Number of CPEs 3
Baseline Privacy Enabled
DOCSIS Mode 3.1
Config file HSUBsgvca69834ncxv9873254k;fg
SFID 24543
Max Traffic Rate 287500061 bps
Max Traffic Burst 42600bytes
Min Traffic Rate 0 bps
SFID 30093
Max Traffic Rate 128000 bps
Max Traffic Burst 4000bytes
Primary Upstream Service Flow
SFID 24544
Max Traffic Rate 27500061 bps
Max Concatenated Burst 42600bytes
Scheduling Type Best Effort
SFID 29878
Max Concatenated Burst 1522bytes
Router is the same in all cases and settings in that have not been changed
Hopefully all the helpful replies i received can see this and thanks again for the help
Comments would be appreciated since I am trying to get faster speeds at the 30 ft range - Maybe I do need a wifi 6 router or one that can handle a 2.5gb feed ?
Regards and thank you all
15-12-2022 09:58 - edited 15-12-2022 09:59
If you have walls in the way of where you want the good wifi signal, I would suggest you invest in another wifi access point in that area. Decent PoE ones start around £120 for wifi 6, some of the more expensive ones will have 2.5Gb NIC's as well. Or get a good wifi 6 Mesh system.
on 15-12-2022 10:11
Thank you
