on 18-11-2022 20:56
Hub 5 wired and wifi keeps losing connection
on 18-11-2022 21:06
1 | 331000000 | 4.8 | 40 | QAM 256 | 25 |
2 | 139000000 | 5.3 | 40 | QAM 256 | 1 |
3 | 147000000 | 5.1 | 39 | QAM 256 | 2 |
4 | 155000000 | 5 | 40 | QAM 256 | 3 |
5 | 163000000 | 5 | 40 | QAM 256 | 4 |
6 | 171000000 | 5.1 | 40 | QAM 256 | 5 |
7 | 179000000 | 5 | 40 | QAM 256 | 6 |
8 | 187000000 | 5.2 | 40 | QAM 256 | 7 |
9 | 195000000 | 5.1 | 40 | QAM 256 | 8 |
10 | 203000000 | 5.1 | 40 | QAM 256 | 9 |
11 | 211000000 | 5.1 | 40 | QAM 256 | 10 |
12 | 219000000 | 4.8 | 40 | QAM 256 | 11 |
13 | 227000000 | 4 | 39 | QAM 256 | 12 |
14 | 235000000 | 4 | 40 | QAM 256 | 13 |
15 | 243000000 | 3.6 | 40 | QAM 256 | 14 |
16 | 251000000 | 3.7 | 40 | QAM 256 | 15 |
17 | 259000000 | 3.6 | 40 | QAM 256 | 16 |
18 | 267000000 | 4.1 | 40 | QAM 256 | 17 |
19 | 275000000 | 4 | 40 | QAM 256 | 18 |
20 | 283000000 | 4.3 | 40 | QAM 256 | 19 |
21 | 291000000 | 4.4 | 40 | QAM 256 | 20 |
22 | 299000000 | 4.7 | 40 | QAM 256 | 21 |
23 | 307000000 | 4.6 | 40 | QAM 256 | 22 |
24 | 315000000 | 4.9 | 40 | QAM 256 | 23 |
25 | 323000000 | 4.8 | 40 | QAM 256 | 24 |
26 | 339000000 | 5.2 | 40 | QAM 256 | 26 |
27 | 347000000 | 5.2 | 41 | QAM 256 | 27 |
28 | 355000000 | 4.8 | 40 | QAM 256 | 28 |
29 | 363000000 | 4.7 | 40 | QAM 256 | 29 |
30 | 371000000 | 4.2 | 40 | QAM 256 | 30 |
31 | 379000000 | 4.1 | 40 | QAM 256 | 31 |
1 | Locked | 40 | 167530 | 101385 |
2 | Locked | 40 | 167715 | 118349 |
3 | Locked | 39 | 102655 | 131669 |
4 | Locked | 40 | 151551 | 124251 |
5 | Locked | 40 | 159841 | 146482 |
6 | Locked | 40 | 120206 | 106949 |
7 | Locked | 40 | 133663 | 145510 |
8 | Locked | 40 | 161592 | 110986 |
9 | Locked | 40 | 161234 | 135936 |
10 | Locked | 40 | 98114 | 112606 |
11 | Locked | 40 | 114645 | 94112 |
12 | Locked | 40 | 181745 | 160180 |
13 | Locked | 39 | 106948 | 118119 |
14 | Locked | 40 | 121583 | 138532 |
15 | Locked | 40 | 87713 | 120584 |
16 | Locked | 40 | 53222 | 50053 |
17 | Locked | 40 | 144436 | 136960 |
18 | Locked | 40 | 95894 | 95048 |
19 | Locked | 40 | 133833 | 118720 |
20 | Locked | 40 | 67214 | 62600 |
21 | Locked | 40 | 72488 | 66257 |
22 | Locked | 40 | 63694 | 59691 |
23 | Locked | 40 | 94257 | 86383 |
24 | Locked | 40 | 120487 | 107023 |
25 | Locked | 40 | 70410 | 66245 |
26 | Locked | 40 | 63511 | 68178 |
27 | Locked | 41 | 83204 | 105468 |
28 | Locked | 40 | 72660 | 77411 |
29 | Locked | 40 | 87515 | 86558 |
30 | Locked | 40 | 67110 | 83061 |
31 | Locked | 40 | 125331 | 116441 |
0 | 49600000 | 46.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 46.5 | 5120 | QAM 64 | 2 |
2 | 36600000 | 46.5 | 5120 | QAM 64 | 3 |
3 | 30100000 | 46.3 | 5120 | QAM 64 | 4 |
4 | 23600000 | 46 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 69 | 18 | 0 |
1 | ATDMA | 0 | 69 | 19 | 0 |
2 | ATDMA | 0 | 69 | 18 | 0 |
3 | ATDMA | 0 | 69 | 18 | 0 |
4 | ATDMA | 0 | 69 | 17 | 0 |
on 18-11-2022 21:45
Too many errors, but the figures are accumulative since the hub was last power cycled. So please turn off your hub for a short period, this will reset the counters, then post a new full set of stats after about two hours. This will indicate the current line status.
on 19-11-2022 21:43
Not so many today.
1 | 331000000 | 4.9 | 41 | QAM 256 | 25 |
2 | 139000000 | 5.4 | 40 | QAM 256 | 1 |
3 | 147000000 | 5.1 | 40 | QAM 256 | 2 |
4 | 155000000 | 5.1 | 40 | QAM 256 | 3 |
5 | 163000000 | 5.1 | 40 | QAM 256 | 4 |
6 | 171000000 | 5.2 | 40 | QAM 256 | 5 |
7 | 179000000 | 5.1 | 40 | QAM 256 | 6 |
8 | 187000000 | 5.3 | 40 | QAM 256 | 7 |
9 | 195000000 | 5.2 | 40 | QAM 256 | 8 |
10 | 203000000 | 5.2 | 40 | QAM 256 | 9 |
11 | 211000000 | 5.2 | 40 | QAM 256 | 10 |
13 | 227000000 | 4.1 | 39 | QAM 256 | 12 |
15 | 243000000 | 3.7 | 40 | QAM 256 | 14 |
16 | 251000000 | 3.8 | 40 | QAM 256 | 15 |
17 | 259000000 | 3.7 | 40 | QAM 256 | 16 |
18 | 267000000 | 4.2 | 40 | QAM 256 | 17 |
19 | 275000000 | 4.1 | 40 | QAM 256 | 18 |
20 | 283000000 | 4.4 | 40 | QAM 256 | 19 |
23 | 307000000 | 4.7 | 40 | QAM 256 | 22 |
24 | 315000000 | 5 | 40 | QAM 256 | 23 |
26 | 339000000 | 5.3 | 41 | QAM 256 | 26 |
27 | 347000000 | 5.3 | 41 | QAM 256 | 27 |
28 | 355000000 | 4.9 | 40 | QAM 256 | 28 |
29 | 363000000 | 4.8 | 40 | QAM 256 | 29 |
30 | 371000000 | 4.3 | 40 | QAM 256 | 30 |
31 | 379000000 | 4.2 | 40 | QAM 256 | 31 |
1 | Locked | 41 | 18634 | 8925 |
2 | Locked | 40 | 17564 | 9457 |
3 | Locked | 40 | 17100 | 12286 |
4 | Locked | 40 | 17779 | 9193 |
5 | Locked | 40 | 17700 | 8423 |
6 | Locked | 40 | 17552 | 7587 |
7 | Locked | 40 | 19114 | 9076 |
8 | Locked | 40 | 20168 | 11480 |
9 | Locked | 40 | 20583 | 9506 |
10 | Locked | 40 | 19305 | 10082 |
11 | Locked | 40 | 19587 | 8044 |
12 | Locked | 40 | 19800 | 10677 |
13 | Locked | 39 | 20375 | 10465 |
14 | Locked | 40 | 18956 | 10277 |
15 | Locked | 40 | 18237 | 8389 |
16 | Locked | 40 | 18585 | 6983 |
17 | Locked | 40 | 19211 | 9217 |
18 | Locked | 40 | 23320 | 9771 |
19 | Locked | 40 | 20748 | 11951 |
20 | Locked | 40 | 23367 | 9161 |
21 | Locked | 40 | 19437 | 8412 |
22 | Locked | 40 | 19927 | 8538 |
23 | Locked | 40 | 20072 | 10079 |
24 | Locked | 40 | 20779 | 12355 |
25 | Locked | 40 | 18883 | 8881 |
26 | Locked | 41 | 17291 | 6576 |
27 | Locked | 41 | 17642 | 9690 |
28 | Locked | 40 | 17655 | 10682 |
29 | Locked | 40 | 17546 | 10767 |
30 | Locked | 40 | 17643 | 9254 |
31 | Locked | 40 | 17341 | 7385 |
0 | 49600000 | 46.5 | 5120 | QAM 64 | 1 |
2 | 36600000 | 46 | 5120 | QAM 64 | 3 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 19-11-2022 23:02
Definitely a problem, you probably need a technician’s visit unless there is an area fault.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 20-11-2022 10:21
No area faults.
I will wait for a VM staff member to get to my post.
Thanks.
on 22-11-2022 12:00
Hey BMWCHUBB, thank you for reaching out and I am sorry to hear you are having some connection issues.
I have taken a look at our side and everything is look prefect and your levels are very good.
I can see last week there was an SNR outage in the area which will affect the overall performance causing issues like this.
However the outage has now ended, has your connection fully restored? Thanks
Matt - Forum Team
New around here?
on 23-11-2022 09:10
Wired seems to be stable now.
Wifi is still randomly stopping and very slow.
on 25-11-2022 10:09
Hey BMWCHUBB, thank you for confirming this.
This would of been caused by the outage, please can you tell me how often the the WIFI is cutting in and out?
I have done some tests from our side and everything is currently looking really good. Thanks
Matt - Forum Team
New around here?
on 25-11-2022 14:38
Hi.
No wifi drop outs for 2 days.
But the wifi is slower than usual for some reason.
