on 24-02-2022 20:49
Since upgrading from Hub 3 to Hub 5, WiFi on some devices is worse. Ethernet is fine. But a Galaxy tablet is sluggish in moving between Web pages or eg viewing video on Facebook. VM support don't seem to have much idea. I have TP link repeater upstairs and connections via this seem better than through Hub direct.
Answered! Go to Answer
on 27-05-2022 07:55
Thanks @EvoVM. That's the solution I'm using at the moment, but madness that my older devices can connect to the 5Ghz network fine, but a new 5G phone has to be throttled by using a 2.4Ghz network in the house. Seems my options now are either argue with Virgin to send me a Hub 4 (instead of the 5) or spend my own money on a wifi router
on 31-05-2022 18:08
@johnrambo18 wrote:Since upgrading from Hub 3 to Hub 5, WiFi on some devices is worse. Ethernet is fine. But a Galaxy tablet is sluggish in moving between Web pages or eg viewing video on Facebook. VM support don't seem to have much idea. I have TP link repeater upstairs and connections via this seem better than through Hub direct.
I have had exactly the same issue. My old HUB2 was replaced first with a HUB3 and then two weeks later with a HUB5. I used the HUB2 in modem mode with a Netgear router and an upstairs extender. The HUB3 worked well on its own but the HUB5 has had the problems detailed in this thread.
I set up the Netgear extender as a WiFi hotspot, sitting next to the HUB5 and using a wired ethernet connection. The "problem" devices connect to the hotspot with no issues.
on 04-06-2022 09:28
Thank for the response maxlugg,
Welcome back to the community.
Just to clarify, has this been resolved for you?
Let us know,
on 04-06-2022 11:27
Hi Kain,
I have worked around the issue with additional equipment of my own, so I'm OK.
The posts in this thread suggest a fundamental problem with the HUB5 WiFi. I haven't fixed that!
on 06-06-2022 14:12
Hi @maxlugg,
Thanks for the update on this - I'm glad to hear things are up and running for you now. I've also passed on the feedback from this thread in regards to the issues with the Hub 5. With the Hub 5 still within a closed trial, I'm sure things will improve before the full release.
Cheers,
on 11-06-2022 12:31
Hi John
I know your post was in Feb and hope ur sorted now.
I myself got the hub 5 yesterday and have been having the same issues. I work in IT myself and while hub 5 is shall we say experimental it's obviously not been tested thoroughly.
Anyway I found a fix for anyone else having the same issues.
If you. Login to your router advanced settings WiFi simply disable the 5ghz and you will be up and running
While 5ghz was on and I was literally 8 feet away from router I was getting 1.4y download speed
After switching off 5ghz I was getting 46mbs download
Hope this helps someone
on 12-06-2022 07:15
Forcing all your devices to use 2.4G by completely disabling 5G is a bit of an overkill. As previously mentioned, you can separate the 2.4G and 5G WiFi networks by giving them different names.
on 26-06-2022 15:17
hi, i recently got the new hub but my laptop cant even see its wifi network? its a few years old but not ancient. is there anything i can do to make it compatible?
i have separated 2.4g and 5g but it shows neither, but shows next door's virgin fine. do i have to swap back to the old hub? i still have it.
on 26-06-2022 15:23
@tip75 wrote:hi, i recently got the new hub but my laptop cant even see its wifi network? its a few years old but not ancient. is there anything i can do to make it compatible?
The Hub 5 is wifi 6 ax protocol and some devices don't like this. Try setting the 2.4Ghz to legacy mode as below;
Access your Hub by navigating to 192.168.0.1
Login with the default login info (on base of Hub) unless you've already updated it.
Go to Advanced Settings > Wireless > Wireless signal
In the Wireless frequency 2.4GHz select Wireless mode > 802.11b/g/n/ax mixed
Select Apply changes
If this still doesn't work, ask to get your old Hub activated.
on 26-06-2022 17:31
yeah i have that set and no joy. bit silly to bring something in when so many devices dont support it
