on 09-07-2022 17:17
Overnight my Hub 5 has stopped working with my Linksys velop wifi mesh network. My hub is In router mode. Was there an upgrade overnight? I have reset the hub And when in router only mode the light is white again??? It was Green as per the recent upgrade. I have reset the hub 5 and notice that in router only mode a MacBook connects ok but a Mac mini does not. Has there been an overnight upgrade on the hub 5? I have spoke. With Linksys and there was not upgrade their side.
09-07-2022 17:28 - edited 09-07-2022 17:31
With the hub in router mode and the Linksys velop wifi mesh in router mode does it work? If not problem might be with the Linksys velop wifi mesh. If it is working something to do with VM DHCP more then likely or try modem mode with a PC with the Linksys velop wifi mesh WAN MAC and not.
You could get Wireshark https://www.wireshark.org/ connect the Linksys velop wifi mesh WAN port to your PC and see if it DHCP note your PC with DHCP too.
on 10-07-2022 18:18
Thanks. I tried this and it worked. Will raise ticket with Linksys.
