on 10-04-2023 21:13
I have Hub 5 with one Virgin pod.
Loaded Virgin Media Connect
Clicked Broadband
Picture shows Hub and 3 wifi pods all with exclamation marks
Selected Hub
Msg Conflicting Settings
Presents two network names, I Selected my router with pod
Msg. Oops something went wrong!
I have no idea what's wrong, rebooted the Hub, no change.
on 13-04-2023 12:32
Virgin Media's back end systems have not correctly updated to reflect the removal of the Hub 3 et al and its replacement with the Hub 5 + new WiFi Pod.
This is one for the VM Support Team to resolve.
on 13-04-2023 17:35
Hi @mikecarter66,
Thanks for your post and welcome to our forums 👋
I am so sorry to hear you have been having issues with your pod and hub. I can see one pod is connected from our systems, this has excellent coverage and connection. I can see your 2.5Gz frequency is at capacity and would benefit from having some devices connected via a wired connection.
How has this been since your post? Are the offline pods the ones you are having issues with?
on 14-04-2023 00:14
Thanks for the msg.
I've got another wifi pod on the way, hopefully it will help with my coverage issue.
I can move my printer to ethernet but struggling with amazon echoes and ring cameras.
on 16-04-2023 11:40
Thanks for the reply / update on the forums @mikecarter66. 👋🏼
Let us know how it goes with the additional Wi-Fi pod and hopefully it should assist with the issues with the coverage and for the other devices.
Kind regards,
Ilyas.
