on 30-12-2022 12:05
my hub 5 doesn’t connect with the connect app. Any ideas?
I’ve done a full pinhole reset (it then worked for 10mins before dropping out)
have deleted and reinstalled the app. Tried it on a different device too.
any ideas on how to connect up?
thanks
on 30-12-2022 13:04
I had this problem with the HUB5. I resolved it by making sure the device with the App installed is connected to the 5ghz network rather than the 2.4ghz network. A bit of a long shot but that worked for me.
Kind Regards,
Bill
on 30-12-2022 15:15
Hi @Moheenhassan,
Welcome to our community forums and thank you for your first posts.
Sorry to hear you are having issues trying to connect your hub 5 to our connect app. We want to best help. Have you tried the great advice given by @BillBudd? If so does the problem persist? Also what happens when trying to connect your hub?
on 30-12-2022 16:19
i tried this via 5g and 2.4 band.
Customer services were absolutely horrible and just wasted my time.
help!
on 02-01-2023 12:58
Thanks for coming back to us @Moheenhassan, can you please confirm what happened when attempting to connect to the 5GHz band?
Do you have any error codes or messages appearing?
Kindest regards,
David_Bn
