on 30-10-2023 16:18
Hello all
Over the last few months, Wi-Fi signal drops have been happening intermittently all day, every day. It seems to effect every device in the house.
the Hub connects to a netgear router then onto various wired connections and a Tenda Mesh system. The live graph has been up and running since last time so I paste that here in case anyone can suggest what cause might be.
Have reset the system and each part but hasn’t helped.
thanks in advance
on 31-10-2023 08:56
With a VM Hub in modem mode the BQM graph plots the responses from the Netgear Router ( not the VM Hub ).
Wi-Fi is not being provided by the VM Hub, so pay close attention to the functioning of the Tenda Mesh, exactly what happens when the Wi-Fi drops out ? E.g. is that the Mesh is dropping the Wi-Fi signal to change channels ?
Hub Signal Level Checks
Via http://192.168.0.1/ connect to the Hub in Router mode, do not login in, scroll down to "Check router status" Use http://192.168.100.1/ for a Hub in Modem mode
Using the Hub's "Check router status" tabs check the Downstream and Upstream power levels are in spec.
( If already logged in to the Hub menu, the same info is available at : Advanced settings >>> Tools >>> Network status )
Downstream Power Levels of -7 to +7 dBmV are preferred, +10dBmV is the max acceptable, with a SNR of 33dB or higher across all DOCSIS 3.0 channels. Rising error counts across many channels is a current service noise fault.
Upstream Power Levels of 35 to 49 dBmV are preferred, with QAM 64 Modulation mode across all four to six DOCSIS 3.0 channels. Seeing QAM 32/16/QPSK is a current service noise fault. Seeing less than four DOCSIS 3.0 channels is usually a signal level fault.
on 31-10-2023 16:32
Problem might be your wifi BQM looks ok to your router
set wifi to use channel 13 on 2.4GHz and 52 on 5GHz
on 31-10-2023 21:13
Thank you. Forgive my ignorance - would this setting change need to be on the net gear router or the Tenda mesh?
on 31-10-2023 21:14
Thank you. I will try this tomorrow and let you know how I get on.
on 01-11-2023 16:04
Have gone to Tenda Mesh Wi-Fi settings - I can make the 2.4GHZ 13 but on 5ghz I don’t have option of 52, I only have 36, 40, 44, 48, 149, 153, 157, 161, 165
which should be best? And will changing these mean devices need to reconnect to the mesh? Thanks.
01-11-2023 16:33 - edited 01-11-2023 16:34
Re 2.4 GHz wifi channels - see this..
on 03-11-2023 16:53
Hello albatross99.
Thanks for bringing this to our attention.
I have just ran a test on the hub from here and can see we have 1 channel issue on your downstream levels.
Also 3 channels on the upstream levels are out of the required range.
It would need one of our technicians out to adjust these, which I can arrange.
If you can check the Logo top right of your screen that would be great.
Gareth_L
on 20-11-2023 09:55
Hello albatross99
Thanks for taking the time to pass security.
I did take a look at a few things and discovered we have an SNR issue in your area
You may find the services are intermittent right now and we are aware of a fault in the area
This fault is logged under reference number F011040819 and is due to be fixed on the 23/11/2023. It kind of ties up with the date of your post as this was first raised on the 31/10/2023
You can pop back on here and ask for an update if you wish. Just quote the reference number above
Gareth_L
on 29-12-2023 13:49
Hello.
unfortunately nothing seems to have changed since end of November. Signal seems to drop constantly. Ref number above to quote was F011040819
Please can I have further update? Or should I be going through other steps to solve the constant dropouts?
do I need to switch to having split 2.4 / 5Ghz signals and go through hassle of changing WiFi passwords for every device in the house?
thanks
