on 10-02-2022 22:17
Hi. My new hub 5 has started to disconnect me from the hub and loose connectivity. Can you pls look into it. If u need any more information pls let me know
Idrees yunis
on 10-02-2022 22:24
What’s disconcerting? Wired or wireless connections?
on 11-02-2022 00:08
The main VM ssid keeps disconnecting me when wirelessly connected to it and when close to the router. I have tried re starting my phone and the router and to no avail
on 11-02-2022 08:35
on 11-02-2022 10:57
Yes. Can a team member look onto this problem for me
Idrees
on 11-02-2022 11:01
staff will get to the post in a few days - in the mean time post the levels from the hub - not seen the UI on the 5 but believe its similar to the 3 and 4 - this is for the 3
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
