on 19-11-2022 10:31
Hi - looking for advice and support as I’m not getting anywhere with VM.
I’m on my second Hub 5 and still experiencing drop outs in connection - it feels like I’m constantly call VM but to no avail, they say they have logged a ticket with 2nd level tech support but I never hear back!
I work from home, my laptop is connected via Ethernet and I still the connection drops intermittently throughout the day. During Teams calls, I can hear other people in the call but I sound like a robot or they only hear some parts of what I’m saying - this is so frustrating!!
This also happens when connected via wifi and is no limited to my laptop - all device are affected.
VM response we’ll send you another wifi pod?! Aarrghhh!
and to top it off they’ve increased the monthly bill?!
Has anybody else experienced this type of issue? Before I switch broadband provider.
Any advice would be much appreciated and probably more helpful than VM.
on 19-11-2022 10:33
Forgot to add this to the original thread
on 19-11-2022 12:13
Hi @mani_bhasin
Your BQM has been rejected as it shows your IP address, you need to remove that and repost the BQM.
It would also be useful for the tech guru's on the forum so that they can look into your issues if you would post the hub stats.
They need the full details from the Router Status page. So please copy/paste 3 FULL sets of data onto here (not screenshots) – from the Downstream, Upstream, & Network Logs pages.
on 19-11-2022 16:29
Many thanks for the advice @newapollo!
Attached are the BQM from yesterday and today:
Also Router Status Data:
1 | 306000000 | 6.8 | 42 | QAM 256 | 22 |
2 | 138000000 | 4.4 | 40 | QAM 256 | 1 |
3 | 146000000 | 4.4 | 40 | QAM 256 | 2 |
4 | 154000000 | 4.7 | 40 | QAM 256 | 3 |
5 | 162000000 | 4.9 | 40 | QAM 256 | 4 |
6 | 170000000 | 5 | 41 | QAM 256 | 5 |
7 | 178000000 | 5.1 | 41 | QAM 256 | 6 |
8 | 186000000 | 5.1 | 41 | QAM 256 | 7 |
9 | 194000000 | 5.2 | 41 | QAM 256 | 8 |
10 | 202000000 | 5.3 | 41 | QAM 256 | 9 |
11 | 210000000 | 5.7 | 41 | QAM 256 | 10 |
12 | 218000000 | 5.9 | 41 | QAM 256 | 11 |
13 | 226000000 | 6 | 41 | QAM 256 | 12 |
14 | 234000000 | 5.9 | 41 | QAM 256 | 13 |
15 | 242000000 | 5.7 | 41 | QAM 256 | 14 |
16 | 250000000 | 5.5 | 41 | QAM 256 | 15 |
17 | 258000000 | 5.7 | 41 | QAM 256 | 16 |
18 | 266000000 | 5.9 | 42 | QAM 256 | 17 |
19 | 274000000 | 6 | 42 | QAM 256 | 18 |
20 | 282000000 | 6.5 | 42 | QAM 256 | 19 |
21 | 290000000 | 7.1 | 42 | QAM 256 | 20 |
22 | 298000000 | 7.2 | 42 | QAM 256 | 21 |
23 | 314000000 | 7 | 42 | QAM 256 | 23 |
24 | 322000000 | 7.4 | 42 | QAM 256 | 24 |
25 | 330000000 | 7.6 | 43 | QAM 256 | 25 |
26 | 338000000 | 7.6 | 43 | QAM 256 | 26 |
27 | 346000000 | 7.8 | 43 | QAM 256 | 27 |
28 | 354000000 | 7.6 | 43 | QAM 256 | 28 |
29 | 362000000 | 7.5 | 43 | QAM 256 | 29 |
30 | 370000000 | 7.3 | 43 | QAM 256 | 30 |
31 | 378000000 | 7.5 | 43 | QAM 256 | 31 |
1 | Locked | 42 | 99 | 0 |
2 | Locked | 40 | 39 | 0 |
3 | Locked | 40 | 33 | 0 |
4 | Locked | 40 | 31 | 0 |
5 | Locked | 40 | 39 | 0 |
6 | Locked | 41 | 30 | 0 |
7 | Locked | 41 | 31 | 0 |
8 | Locked | 41 | 42 | 0 |
9 | Locked | 41 | 48 | 0 |
10 | Locked | 41 | 39 | 0 |
11 | Locked | 41 | 58 | 0 |
12 | Locked | 41 | 48 | 0 |
13 | Locked | 41 | 57 | 0 |
14 | Locked | 41 | 68 | 0 |
15 | Locked | 41 | 57 | 0 |
16 | Locked | 41 | 75 | 0 |
17 | Locked | 41 | 63 | 0 |
18 | Locked | 42 | 64 | 0 |
19 | Locked | 42 | 76 | 0 |
20 | Locked | 42 | 74 | 0 |
21 | Locked | 42 | 66 | 0 |
22 | Locked | 42 | 81 | 0 |
23 | Locked | 42 | 107 | 0 |
24 | Locked | 42 | 105 | 0 |
25 | Locked | 43 | 103 | 0 |
26 | Locked | 43 | 103 | 0 |
27 | Locked | 43 | 95 | 0 |
28 | Locked | 43 | 91 | 0 |
29 | Locked | 43 | 124 | 0 |
30 | Locked | 43 | 121 | 0 |
31 | Locked | 43 | 115 | 0 |
0 | 46200000 | 49.3 | 5120 | QAM 64 | 1 |
1 | 39400000 | 49.3 | 5120 | QAM 64 | 2 |
2 | 32600000 | 49.3 | 5120 | QAM 64 | 3 |
3 | 25800000 | 49 | 5120 | QAM 64 | 4 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
18-11-2022 07:32:08 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
18-11-2022 07:32:01 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-11-2022 07:31:59 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-11-2022 07:31:57 | notice | Honoring MDD; IP provisioning mode = IPv4 |
18-11-2022 07:31:50 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-11-2022 07:31:44 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-11-2022 07:31:32 | critical | Cable Modem Reboot due to master console reset |
on 19-11-2022 16:58
on 19-11-2022 17:34
Thanks @jbrennand I’ve checked all cables at the back of the hub 5 and everything seems good - however good shout about the box outside I shall take a look in the morning.
on 20-11-2022 16:29
I checked the grey box outside my house. All seems good, connection is tight but still experiencing issues
on 20-11-2022 16:54
on 20-11-2022 16:56
Just my work laptop and wd cloud NAS that are connected via Ethernet
20-11-2022 17:19 - edited 20-11-2022 17:25
See this as an experiment...
_________________________
There is another possibility, there have been several threads on here recently where similar BQM latency/packet loss problems were eventually pinned down to a dodgy piece of connected kit affecting the connection . Bad connectors on ethernet cables, external drives, and faulty network switches being high on the list of suspects
What I advised was... if you run the BQM for 24h to get a picture of the issues (you have done this) - and then unplug all the ethernet cable connections from the Hub and just let it run - overnight is best.
Then in the morning look at the BQM and see if it has cleaned up. If it has - plug the devices back in one at a time for an hour or two until the problem reappears and that should indicate where to look for what is causing the issues
Examples.
See message 21 in the first and 13 in the second.
https://community.virginmedia.com/t5/Networking-and-WiFi/Internet-connection-dropping/td-p/4781287/p...
https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-Connection/td-p/5069984/page/2
