on 31-01-2022 21:43
Hi! We recently had a hub 5 installed (upgrade from a hub 3) and since then our connection has been cutting out every couple of minutes, it does this over both wifi and ethernet, you can connect to the router fine and reboot it etc. during this time however you can't open any pages etc. (sadly rebooting it and factory resetting it hasn't resolved the issue)
I had a look around to see if I was getting any errors on the hub and I seem to be getting an insane amount of post rs errors, in addition the network log is filled with MDD message timeout and CM-STATUS message sent messages
Any help with this would be greatly appreciated! I tried calling them up but haven't managed to get through to anyone when I've tried.
on 31-01-2022 21:44
Here's the downstream and upstream logs if they help, the router was factory reset last week
1 | 331000000 | -4 | 39 | QAM 256 | 25 |
2 | 139000000 | -1.1 | 40 | QAM 256 | 1 |
3 | 147000000 | -1 | 39 | QAM 256 | 2 |
4 | 155000000 | -1.1 | 39 | QAM 256 | 3 |
5 | 163000000 | -1.5 | 38 | QAM 256 | 4 |
6 | 171000000 | -2.2 | 40 | QAM 256 | 5 |
7 | 179000000 | -2.3 | 41 | QAM 256 | 6 |
8 | 187000000 | -2.3 | 41 | QAM 256 | 7 |
9 | 195000000 | -2 | 41 | QAM 256 | 8 |
10 | 203000000 | -2.1 | 41 | QAM 256 | 9 |
11 | 211000000 | -2.2 | 41 | QAM 256 | 10 |
12 | 219000000 | -2.3 | 37 | QAM 256 | 11 |
13 | 227000000 | -2.4 | 39 | QAM 256 | 12 |
14 | 235000000 | -2.6 | 41 | QAM 256 | 13 |
15 | 243000000 | -2.7 | 41 | QAM 256 | 14 |
16 | 251000000 | -2.9 | 41 | QAM 256 | 15 |
17 | 259000000 | -3 | 41 | QAM 256 | 16 |
18 | 267000000 | -2.9 | 40 | QAM 256 | 17 |
19 | 275000000 | -3.2 | 40 | QAM 256 | 18 |
20 | 283000000 | -3.3 | 40 | QAM 256 | 19 |
21 | 291000000 | -2.8 | 40 | QAM 256 | 20 |
22 | 299000000 | -3.1 | 40 | QAM 256 | 21 |
23 | 307000000 | -3.1 | 40 | QAM 256 | 22 |
24 | 315000000 | -3 | 39 | QAM 256 | 23 |
25 | 323000000 | -3.3 | 39 | QAM 256 | 24 |
26 | 339000000 | -4.2 | 39 | QAM 256 | 26 |
27 | 347000000 | -4.1 | 39 | QAM 256 | 27 |
28 | 355000000 | -3.7 | 40 | QAM 256 | 28 |
29 | 363000000 | -4 | 40 | QAM 256 | 29 |
30 | 371000000 | -3.9 | 40 | QAM 256 | 30 |
31 | 379000000 | -3.4 | 40 | QAM 256 | 31 |
1 | Locked | 39 | 25 | 44 |
2 | Locked | 40 | 53 | 898 |
3 | Locked | 39 | 38 | 1453016 |
4 | Locked | 39 | 86 | 713 |
5 | Locked | 38 | 47 | 608 |
6 | Locked | 40 | 54 | 273 |
7 | Locked | 41 | 40 | 208 |
8 | Locked | 41 | 33 | 393 |
9 | Locked | 41 | 41 | 137 |
10 | Locked | 41 | 34 | 121 |
11 | Locked | 41 | 40 | 124 |
12 | Locked | 37 | 34 | 152 |
13 | Locked | 39 | 30 | 219 |
14 | Locked | 41 | 42 | 736 |
15 | Locked | 41 | 31 | 275 |
16 | Locked | 41 | 42 | 76 |
17 | Locked | 41 | 35 | 174 |
18 | Locked | 40 | 27 | 102 |
19 | Locked | 40 | 21 | 177 |
20 | Locked | 40 | 35 | 85 |
21 | Locked | 40 | 40 | 16 |
22 | Locked | 40 | 31 | 48 |
23 | Locked | 40 | 39 | 25 |
24 | Locked | 39 | 41 | 19 |
25 | Locked | 39 | 32 | 34 |
26 | Locked | 39 | 1 | 48 |
27 | Locked | 39 | 26 | 9 |
28 | Locked | 40 | 26 | 32 |
29 | Locked | 40 | 28 | 125 |
30 | Locked | 40 | 31 | 109 |
31 | Locked | 40 | 31 | 38 |
1 | 60300000 | 47.5 | 5120 | QAM 64 | 1 |
2 | 53700000 | 47 | 5120 | QAM 64 | 2 |
3 | 46200000 | 46.5 | 5120 | QAM 64 | 3 |
4 | 39400000 | 45.5 | 5120 | QAM 64 | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
31-01-2022 21:57 - edited 31-01-2022 21:58
Can I take it that the previous Hub 3 worked OK? The stats you posted don’t look too bad other than one downstream channel, but to be honest, I can’t really trust what the hub reports considering all of the other reported issues with it.
By the way, you were aware that the Hub 5 was offered to customers on a ‘trial’ basis, i.e. did have known issues and faults which you were acting as beta (if not alpha) testers for? No? Thought not?
OK you have done the obvious, complete factory reset etc. Call VM, select the ‘thinking of leaving us’ option and demand that they replace the hub with a Hub 3 on the grounds that it is a trial device, not working and not fit for purpose. Neither were you formed that it was a ‘trial’ hardware with known issues. Drop the term ‘informed consent’ into the conversation, usually sets the legal alarm bells ringing!
on 01-02-2022 09:09
01-02-2022 09:20 - edited 01-02-2022 09:21
just to add - only speak to someone in the UK - the reasons excuses why its not possible to swap back to the hub3 from offshore get dafter by the day
the last one i heard was that the cables had been upgraded for the hub5 and these new cables were not compatible with earlier hubs - full marks for originality or should that be for bulls droppings
dial 150 or 0345 454 1111 and follow the prompts to - 'thinking of leaving us' - dont worry about that they do much more - open 8am -10pm 7 days a week - should take you to a UK call centre
theres a freephone number 0800 052 0422. You need option 4 to speak to retentions
