Hub 5 and Modem mode
Callinder
Dialled in
I'm a tad confused. On the surface, as I want to use a Mesh system, setting the Hub 5 in modem mode would be a piece of cake. That was until I read numerous posts saying it had been disabled or there was a problem. Of course I checked the official VM advice and saw this -
How do I put a Virgin Media Hub into modem and router mode?
How to turn on modem mode on the Virgin Media Hub 3, 4 or 5* and Super Hub 1, 2 or 2AC
I noticed the * and found this -
*Not currently available for Hub 5x
Can anyone say what this means because to me this indicates modem mode for the Hub 5 is NOT available.
1 ACCEPTED SOLUTION
Accepted Solutions
g0akc
Problem sorter
I can't be sure that the Hub 5 supports modem mode (I presume it does) but I do believe the Hub 5x is not the same as the Hub 5 - see THIS link
The Hub 5x is for full fibre connections - where there is a fibre to the property, not a coax - what type of cable comes into your house?
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
5 REPLIES 5
Cardiffman282
Super solver
It's available on the 5 but not on the 5X.
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
g0akc
Problem sorter
Callinder
Dialled in
I'm pretty certain that I don't have a full fibre connection since the cable to my home is the same one used over 10 years ago by NTL, or it could have been Telewest, after they bought Cable London. I may just have a bash and see what happens!
carl_pearce
Community elder
The HUB 5 NONE x 100% supports modem mode as I use it myself.
Callinder
Dialled in
Thanks for confirming this. Once I heard that Hub5* meant full fibre cable I was pretty certain I'd be OK.
