on 22-04-2023 22:45
Long story short.
Had a Hub 5 that was defective. Got an engineer out who simply swapped out for a new Hub 5, connected cables and left, telling me it could take up to an hour to activate.
90mins later, still no activation, merely a flashing blue light. I called Virgin up, advised that they’d ran some checks, but the modem wasn’t showing up on their network. They said now another technician would need to come out and that would be in three days time and no Internet in the meantime.
i’m very confused. I’ve gone from having an old hub intermittently working with Internet, to a brand-new hub with no internet that the technician just swapped out failing to check anything.
literally none of the cables have changed from Monday the old hub that was working, so I’m really confused as to why the new hub isn’t working and why it might be a cable issue.
can anybody offer any tips or advice? Incredibly frustrated by the whole experience .
on 22-04-2023 22:53
on 22-04-2023 22:59
Thanks for the quick response.
no, the technician took the old one away, so totally disconnected right now.
im hoping it somehow resolves itself overnight. I tried calling that activation number and that’s how I’ve now ended up with needing to have yet another technician call.
im *extremely* miffed as literally nothing has changed in my setup bar the swapping of the modem. Double miffed that having had a technician out today, within 90mins I’ve had to arrange another one and am in a far worse position than I was this morning.
i work from home and this enormously inconvenient and impactful.
on 22-04-2023 23:01
on 23-04-2023 07:58
Thanks. Tried this and no joy…
on 25-04-2023 11:32
Hi jones79, thanks for the message and welcome back to the forums.
I am sorry to hear that there is an issue with the hub, can you confirm if you are experiencing issues with this?
How is the service since posting?
Kind regards, Chris.
on 25-04-2023 11:35
Hi Chris
No change whatsoever. Still zero Internet. TV is working fine (apart from any online services).
Technician is due this afternoon...Will update once I know what the issue is/was in case it helps others.
on 25-04-2023 11:40
Connect to the Hub with a browser to 192.168.0.1 - Do not login, but just click "Router Status" beneath the login box.
What does the Provisioning State show on the Status tab ?
on 25-04-2023 11:44
It says:
Provisioning State | Requesting CM IP address | dhcp_v4_in_progress |
on 25-04-2023 11:45
Should add that it's said that since Saturdah
