marekthomasx1
  • 51
  • 11
Hub 5 Provision issue+Disabling WiFi
Hello all, little bit concerned about what’s happened recently.
Had an NPD (oops, forgot i changed banks) and the hub started flashing blue at around midnight after taking a restart, and it’s like the WPS light but goes away after startup. I’ve had a look at my logs and settings and noticed a) once paid WiFi is greyed out to reenable from hub. b)some T3 timeouts that i’m not sure about and c) no ability to change meaning no Wireless until 8am when VM open! keeps happening when i restart my hub. done the usual pinhole reset stuff but no avail. here are some photos of my xbox (sorry, don’t own a laptop or PC atm and cannot reenable, ethernet is the only thing that works so can’t screengrab!) and any help is welcome!
  • 35.04K
  • 3.41K
  • 6.66K
Re: Hub 5 Provision issue+Disabling WiFi
Is it sorted yet?
marekthomasx1
  • 51
  • 11
no 😞
  • 35.04K
  • 3.41K
  • 6.66K
So to clarify...
Have you got any network connectivity at all - you said ethernet is working?
If so you haven been cut off for NPD.
So check first for any “known network faults - Try in 2 places
1) Try the “check service,”Area status webpage" (link at top right of this forum)
2) Then also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level.
marekthomasx1
  • 51
  • 11
apologies, after calling VM they managed to reenable it after diagnosing the router’s profile was wrong. are the T3 Timeouts anything to worry about?
  • 35.04K
  • 3.41K
  • 6.66K
Possibly ... we need to see the whole picture though - can you d this...
_____________________
Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
