on 13-04-2022 01:19
Recently received the Hub 5 however my PC is having major issues with keeping a solid connection over WIFI to the hub, looking on the forum it seems I may not be alone.
Firstly it appears to be solely to do with my PC. I have not noticed any other issues with any other devices wired or wireless. They also did not occur with the previous hub i had.
My PC on the other hand regularly struggles to connect giving the error 'can't connect to this network' or will constantly drop a signal (several times an hour) sometimes it will reconnect sometimes it won't. A reboot of the router seems to do the trick most of time but after a while the problem reoccurs...
There doesn't seem to be a definitive answer on the issue but these are the things I have tried:
If anyone has any other possible solutions I would be grateful, thanks
on 13-04-2022 15:55
on 13-04-2022 17:03
on 18-04-2022 09:55
Hi md1239,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue you've been having with your broadband service.
I have taken a look on our system and it we will need to do some more checks on this.
I will private message you to confirm some details.
^Martin
on 20-04-2022 16:54
Thank you for the reply,
I think it may be the way to go, It is very frustrating as the performance of the hub at longer distances is much improved. When it works I'm Getting about 4x the speed where my computer is compared to my old hub, but i guess the key there is when it works!
