on 12-03-2022 10:58
I have a Hub 5, but am having real problems with it. My Android phone - a Blackview A100 running Version 11 - keeps disconnecting from the wifi network. It then connects to data - and takes about 10-15 seconds to reconnect to the wifi. Sometimes it doesn't like to connect at all. I also have problems with other wifi devices connecting consistently to the network (eg ispindel).
I never had these problems with my phone with previous router - and the phone works well on other wifi networks without an issue. There no problem with the internet connectivity: others' devices are fine, as are the wired devices (like TV, Xbox, etc).
I have tried doing the usual things, including network reset (on phone and on Hub 5) and splitting the network into a 5ghz and 2.4 ghz networks. But none of it has worked. I had great service with the Hub 4, but this is a real pain and it needs a resolution. Help please!
on 12-03-2022 21:12
You need to get a better router with 1Gb ports the hub 5 has problems its better in modem mode
on 13-03-2022 08:53
Hello @Vauban,
Welcome, thanks for posting.
I am sorry for the issues with your phone.
Can you please tell me if you have contacted the manufacture of the phone? As your other devices seem to be working okay?
Many thanks.
on 13-03-2022 09:27
Thanks for replying. The problem only seems to affect my android phone and the WiFi ispindel device (which keeps disconnecting from the network). It's not a problem with the phone - because a) the phone works on every other WiFi network without any issue and b) it also worked fine before Virgin upgraded me to a hub 5. The problem is with the hub 5 unfortunately.
The resolution I am looking for, if it's not possible to fix this comparability issue between my android phone (and other WiFi devices) and the new hub is to revert to a hub 4. Because at the moment I am not getting the service I am paying for.
on 13-03-2022 09:42
For many people on here the Hub 5 is currently proving to be unfit for purpose. It is also still being trialled on a very limited basis presumably because of this. I think by process of elimination you have clearly demonstrated that it is the Hub that is at issue here not your phone. Call customer services and ask to revert back to the hub 4 for this reason.
on 13-03-2022 10:15
Thanks for the response @Vauban,
Are you wanting to do a Hub swap? If so I can help you with this.
Let me know.
on 13-03-2022 10:18
Yes please Hayley - may I go back to the Hub 4 (as everything was fine with that)?
on 13-03-2022 10:45
One last thing to try perhaps? Set the Hub 5 wifi to a lower legacy setting as below;
Access your Hub by navigating to 192.168.0.1
Login with the default login info (on base of Hub) unless you've already updated it.
Go to Advanced Settings > Wireless > Wireless signal
In the Wireless frequency 2.4GHz select Wireless mode > 802.11b/g/n/ax mixed
Select Apply changes
on 14-03-2022 20:30
Thanks. I thought this might have fixed it - but it doesn't seem to have unfortunately.
Hayley: can you arrange for a reversion of Hub5 to Hub4 please?
on 16-03-2022 12:32
Hello @Vauban,
Sorry for the delay in getting back to you, please do not private message without me inviting you first, otherwise it can cause me to miss your message. I will send you a private message from this thread now so I can help you with this.
Please look out for my message.
Many thanks,
