corbetta
  • 107
Dialled in
Message 1 of 18
Hub 5 - HTTP Error 500
Hi - when I try and access my router using http://192.168.0.1 (as printed on the router label) I get this error:
Lee_R
  • 6.89K
  • 326
  • 736
Message 2 of 18
Re: Hub 5 - HTTP Error 500
Hi @corbetta, thanks for reaching out, sorry to hear that you've been unable to log into your hub 5.
Have you had any success since posting?
Lee_R
corbetta
  • 107
Dialled in
Message 3 of 18
Hi, I did a pinhole reset and I can now get to the login page
Hayley_S
  • 3.9K
  • 129
  • 255
Message 4 of 18
Hello @corbetta,
Thank you for the update, has this resolved your issue?
Many thanks,
Hayley
mcmorley
Message 5 of 18
My new Hub 5 produces this error on a regular basis, I have to keep rebooting the hub 5 to clear the error and then after a period of time the error comes back, obviously something is not correct with the hub 5. Here is my error on my Hub 5;
Internal server error: CosaError: CcspBaseIf_getParameterValues() failed: "Device.X_CISCO_COM_CableModem.IPAddress" Stack: CosaError: CcspBaseIf_getParameterValues() failed: "Device.X_CISCO_COM_CableModem.IPAddress" (errorCode=192) at [anon] (/usr/src/debug/ccsp-jse/8888+gitAUTOINC+71cde0c8c5-r0/git/source/jse_cosa_error.c:118) internal at [anon] () native strict preventsyield at isRemoteRequest (/www/jse/library/auth.js:74) at [anon] (/www/jse/rest/v1/system/ui/screens.js:91) at [anon] (/www/jse/rest/v1/system/ui/screens.js:163) tailcall at global (/www/rest/front.jse:369) preventsyield (0)
Cancel
mcmorley
Message 6 of 18
HTTP Error 500 "Internal Server Error"
mcmorley
Message 7 of 18
Re: Hub 5 - HTTP Error 500 "Internal Server Error"
Rebooted my Hub 5 last night, I can now access it via 192.168.0.1
I am now getting the following error;
Internal server error: Error: Unrecognised CCSP downstream modulation "" Stack: Error: Unrecognised CCSP downstream modulation "" at getDSModulationAPIValue (/www/jse/rest/v1/cablemodem/downstreamchannel.js:42) at getDownstreamChannel (/www/jse/rest/v1/cablemodem/downstreamchannel.js:61) tailcall at [anon] (/www/jse/rest/v1/cablemodem/downstream/primary.js:61) tailcall at global (/www/rest/front.jse:369) preventsyield (0)
Cancel
Ayisha_B
  • 4.46K
  • 174
  • 396
Message 8 of 18
Hi @mcmorley,
Welcome to our Community Forums and thanks for your post.
Sorry to hear you've been having similar issues. If you are still getting any errors I'd suggest a pinhole reset as opposed to just a reboot.
Keep us posted.
Ayisha_B
mikez
  • 43
  • 6
Message 9 of 18
I am having the same problem. Getting pop-up with HTTP Error 500 "Internal Server Error" and a lot error text.  I rebooted it and it goes away and no doubt will be back soon.
Not as worrying as the massive security hole where you can't actually disable uPNP on the Hub 5 (even though it says it's disabled!) but still annoying
Mike
Beth_G
  • 5.24K
  • 301
  • 559
Message 10 of 18
Hi Mike and Corbetta,
I'm sorry to hear that you both seem to be getting a HTTP error with your Hub 5
I'm going to pop you both over a PM so I can take some details and look into this for you both. Please do look out for my messages over at the purple envelope
Beth
