on 03-12-2022 16:14
My Ethernet ports have suddenly stopped working on Hub 5. The leads are connected fine. I have even had a new Hub 5 replacement sent but the Ethernet ports are still not working. The Wi-Fi is fine
Answered! Go to Answer
on 03-12-2022 16:51
03-12-2022 16:36 - edited 03-12-2022 16:37
Two Hub5's both with non working ethernet ports - sounds unlikely - the issue may lay elsewhere
Have you tried new Cat6a ethernet cables.? Do the cable ends light up when plugged in?
Have you got it in modem only mode - what colour is the hub light? In modem mode all the ports are inactivated (except one)
on 03-12-2022 16:48
Hi John, I haven’t changed any settings. No port lights are lit up also on the hub 5. There are 4 Ethernet ports connected and not one is working. They were all working around a week ago and then stopped suddenly
on 03-12-2022 16:51
03-12-2022 18:17 - edited 03-12-2022 18:18
@jbrennand wrote:Two Hub5's both with non working ethernet ports - sounds unlikely - the issue may lay elsewhere
Unless VM are resending out 2nd hand hubs without testing them?
get new cables
on 02-02-2023 10:17
Did anybody get to the bottom of this issue?
My hub has also started stopping from allowing the ethernet ports connecting to the internet. I re-started the router yesterday and that solved the issue temporarily, but it has happened again today. There have no system changes at our end. We have had both an Apple TV and a smart heating bridge connected via ethernet for about 12 months but yesterday it blocked them both. The apple box still works via wifi.
Both ethernet connected devices have no access to the internet.
on 04-02-2023 10:32
Hi KevJZeeeee. Can you disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin ^Chris
on 17-05-2023 16:27
Such an NPC response, similar to the original ‘solution’. The issue still persists even after this!
on 19-05-2023 16:44
Hi @Jamesvoxel 👋 Thank you for your post and welcome to the Virgin Media Community 😀
We're sorry to hear you're continuing to experience the issue 😔
Have you tried calling our customer service team and reporting the fault, as advised on another thread? If so, what did they suggest in terms of a resolution?
Regards,
Daniel
