on 10-07-2022 08:19
I have had the HUB 4 for a couple of years and it has never worked efficiently constantly buffering and freezing and sometimes suddenly stopping streaming and closing down , I wish I had never upgraded from the previous hub
on 10-07-2022 14:49
Try a 30 second pinhole reset of the hub with no ethernet connection and ensure that all cables and connections are tight and secure and not kinked or damaged.
on 12-07-2022 15:35
Hi there @malcbeex
Thank you so much for your post and welcome to the community forums, it's great to have you on board!
I'm so sorry to hear that you are facing this issue and a big thank you to @Anonymous for their help and guidance so far.
Have you been able to try the pin hole reset as they advised?
Thank you.
