on 15-04-2022 14:18
Since I received my new hub 4 router I’ve been having trouble connecting to my cctv.
the cctv is connected to the hub via Ethernet, but I’m having trouble connecting via Wi-Fi to my mobile phone. Never had any problems until I got this new hub. If I unplug and plug back in the Ethernet it works for about 5 mins. Then when I check again it says connection failed. It’s driving me mad I’ve run tests etc on the hub, changed the Ethernet cable but it still happens. Any advice would be welcomed
on 15-04-2022 14:39
Are you connecting via an app? Which one? Is it to the WAN side or LAN?
on 15-04-2022 14:42
The app is iVMS-4500 for the hikvision cctv.
on 15-04-2022 17:01
@Tina1971 wrote:The app is iVMS-4500 for the hikvision cctv.
Have you seen that app and the service has been discontinued
try their new app
on 15-04-2022 22:45
Ok so I played around with the settings on the hub and in advanced settings/security/wireless MAC filtering if I select allow the cameras work on my mobile phone but the actual Wi-Fi says cannot join the network. I have a booster plug so the internet is going through that and my phone is connecting to that network.
on 16-04-2022 08:49
@Tina1971 wrote:Ok so I played around with the settings on the hub and in advanced settings/security/wireless MAC filtering if I select allow the cameras work on my mobile phone but the actual Wi-Fi says cannot join the network. I have a booster plug so the internet is going through that and my phone is connecting to that network.
I don't know how the camera is working or how it's connecting.
IP Security cameras (I'm excluding those connected via coax) can connect in a number of ways including;
You haven't answered my earlier question about how it's connecting - is an IP address set in the app, for example?
Are any Port forwarding rules set on the hub?
Have you tried with an external internet connection such as mobile data or Wi-Fi at another house/pub/coffee shop ?
Regardless - given that, as shown in the link I provided earlier, the manufacturer stopped supporting the app you are using in February, and apparently took the service (servers, DDNS etc.) away I suggest you follow their advice and update to their new app and service. We could spend ages trying to troubleshoot otherwise.
See if the cameras work properly with the manufacturers new service and let us know..
