on 08-10-2021 10:16
I’ve just order the new hub 4 I was wondering if my house phone will work with this as just had our house phone put into hub 3 ,
will I need to get a engineer out to set it up on the new hub
on 08-10-2021 18:30
If you previously had a VOIP line you will continue to have it on the Hub4
on 08-10-2021 19:17
Many thanks
on 11-10-2021 08:43
Hi @Simonst,
Thank you for your posts. As I can see @jb66 has advised, this will work exactly the same for you via your Hub 4 as it did with the Hub 3. You just need to connect the landline into the router using the adapter.
You can also find more information on this here.
