  • 5
Message 1 of 7
Hub 4 wifi issues
I took delivery of a new Hub 4 in September and we’ve experienced continuous connection dropouts across all unwired devices ever since. We have done all the usual checks and tried calling VM spending nearly an hour on hold at a time with no success getting through. It’s getting highly frustrating when attempting to work from home with numerous video calls throughout the day.
Virgin media - PLEASE can I get engineer support as there is clearly an issue with your Hub 4 going by the other posts that I can see.
Jess
Tags (3)
  • 24.55K
  • 1.41K
  • 3.12K
Message 2 of 7
Re: Hub 4 wifi issues
If wired connections are fine then put the hub into modem mode and use your own router or mesh system.
  • 5
Message 3 of 7
I only have one thing that’s one wired (via a Ethernet cable) everything else I use is via wifi. I don’t have my own router I rely on the virgin hub 4 so don’t really want to buy extra equipment to make something that previously worked (when I had the hub 3) work.
  • 24.55K
  • 1.41K
  • 3.12K
Message 4 of 7
Then you’ll be relying on inferior WiFi until you do.
  • 5
Message 5 of 7
Well thank you for your input gary-dexter
Virgin media - any advice please?
  • 24.55K
  • 1.41K
  • 3.12K
Message 6 of 7
They won’t give you any advice or send an engineer for WiFi issues.
Plus you’ll be waiting at least a week for a mod to reply.
  • 1.89K
  • 126
  • 176
Message 7 of 7
Hi Jaycee272,
Thanks for your post on the Community Forums, many apologies for our delayed response.
I'm sorry to hear you've been facing some issues with your WiFi connection since installing your Hub 4. As Gary has advised, if it's only wireless devices which are experiencing issues, it mean that it's either an issue with your home WiFi set up, or an issue with the router itself.  Do all your devices drop at the same time?
I would also recommend taking a look at our WiFi hints and tips, to ensure that all your equipment is set up in the best way possible and you're getting the best out of your home WiFi set up. Even having your hub on the floor or in a confined space can have a noticeable affect on your connection and coverage, so it's worth taking a look.
Let me know if you still need help.
Beth
