on 09-02-2022 12:23
Been trying for days now to split my ssid 2.4 and 5 I rename them but when I search I can only see the one I named 5g. I’m trying to connect a ring doorbell but can’t as I need 2.4 been on the phone to virgin for over an hour the said do a hard reset and try again. I knew this wouldn’t work and I was right. Can anyone help please
on 09-02-2022 15:49
on 11-02-2022 17:26
Hi @Pompyblade
Welcome to our Community Help Forum 🙂
Thank you for making this post regarding the issues you are experiencing with your new Hub 4, I'm sorry to hear you are unable to find the 2.4ghz channel.
Please can you type http://192.168.100.1 into your web browser then enter the router settings password in the box shown on screen. After logging into your router, click the "Wireless Network Settings" button. Locate the "Wireless Band" settings option and check the "2.4 GHz" option. For maximum compatibility, ensure that the 5 GHz box is unchecked. After setting these options, click "Save Settings."
Does this enable you to connect Ring Doorbell?
Best wishes,
Serena
