on 08-08-2022 12:24
Our Hub 4 is running hot and often making a whirring noise. It is in a very shady but very well ventilated location. We first noticed this problem before the weather started getting hot again. Of course Virgin is hiding away and it has been impossible to talk to a human. We have made an appointment for a technician to call but it that visit is a couple of days away.
All suggested checks through Virgin apps etc have been done. Any other constructive suggestions as to resolving the problem etc are welcome.
on 08-08-2022 14:52
on 08-08-2022 15:30
Hi @AB1918,
Thanks for your post, and welcome back to our Community.
I'm really sorry to hear your Hub is having issues with regulating temperature and noise. I've taken a look at things on our end and can see your Hub has been online for a few days. Everything is also showing within standard running specifications.
I've attempted to pull this appointment forward, but due to the extremely high demand in Technician visits, I have been unable to do so.
Can you please switch off your Hub and unplug it from any power supply and then take a look at the base to see if there has been any build-up of dust? Once you've taken a look at this, please plug your supply back in and turn the Hub back on and see if the issue is persisting.
If the Hub is still getting hot and making noise, then as @jbrennand has mentioned, as a safety precaution, please unplug the power supply directly at the socket when you are out of the home or sleeping - or, if possible, for the entire duration of the time between now and your Technician visit.
on 08-08-2022 16:53
Thanks for the message,
All suggestions followed.
If we need to switch off the hub completely, how can we maintain our wifi for the 70+ hours until a Virgin technician arrives.
on 10-08-2022 18:03
Thank you @AB1918
Are you able to let us know how things are looking after this appointment?
Thank you again
