on 08-04-2022 21:02
I had an engineer visit this week an forgot to ask him!!!!
My hub 4 restarts randomly … nine times since 1st January.
is this normal or is something wrong?
on 09-04-2022 01:45
Hubs very very rarely restart on their own, you can tell if they do by records in the log with a date of 01/01/1970.
What probably is happening is the hub is losing connection to the VM CMTS, the equipment at the other end of your cable. It then goes into a retry loop until connection is reestablished. When it happens:
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level
on 09-04-2022 07:12
Hi Cheers
No 1970 entries it only goes back to frying the log 🤔
Interestingly the hub went down at 8:40 last night, I was using landline at the time. Cut off call pulsing white led ring for a few minutes then everything worked again.
Router stats now showing 10.5 hours uptime which is correct but…
The last entry in the network log is 3 days ago!
on 09-04-2022 07:14
No 1970 entries it only goes back to feb in the log
on 12-04-2022 15:56
Hi Dusty_Warrior, thanks for the message and sorry to hear that you are having issues with the hub, i have checked the hub and we need to look into this further for you and I will send you a private message. Please look for the purple envelope. ^Chris.
on 13-04-2022 19:07
I have replied to your PM
