on 20-11-2021 17:56
Can someone have any idea how to fix my hub 4 not working after a power outage this afternoon. Reboot the hub several times but no success. Try the reset function for over 60 seconds but nothing. Flashes white and then red static.
on 20-11-2021 18:37
Could have taken out some VM equipment
Check with Area faults on 0800 561 0061 or if you have a VM landline 150
on 22-11-2021 18:52
Hi Steveaus77,
Thank you for your post and welcome to forums 🙂
I am sorry to hear you are having issues with your Hub 4, I have managed to locate your account and can see you have some power level issues that require a tech.
I can get this booked in for you and will pop you over a private message to confirm some details. Just keep an eye out for the purple envelope 🙂
Zoie
