Nigel1971
  • 199
  • 7
  • 9
Up to speed
Message 1 of 10
Hub 4 not displaying logs
Twice in the last couple of weeks, the hub is not displaying the network logs in the router stats on the networking tab and today is totally blank shown here. Is it a fault or what? been 2-3 dropouts earlier today but fine at the moment
3.0 Downstream channels
20Locked33.8341641370
1Locked33.8341641520
2Locked33.8341641360
3Locked33.4865424240
4Locked33.3765915720
5Locked33.0625047730
6Locked32.67620827120
7Locked32.67620840180
8Locked32.67620826390
9Locked32.96266212730
10Locked32.9626629690
11Locked32.9626628030
12Locked33.0625047350
13Locked33.0625049590
14Locked33.4865423400
15Locked33.0625048540
16Locked33.0625047350
17Locked33.3765912120
18Locked33.4865422970
19Locked33.4865422270
21Locked33.8341641350
22Locked33.9565091660
23Locked33.4865422230
24Locked33.834164940
25Locked34.483570140
26Locked34.483570120
27Locked34.483570120
28Locked34.92561050
29Locked34.92561050
30Locked34.92561020
31Locked35.08354930
——————————————— My Broadband Ping - Virgin 500mb Home Connection
Zoie_P
  • 5.28K
  • 218
  • 409
Message 2 of 10
Re: Hub 4 not displaying logs
Hi Nigel1971,
Thank you for your post 🌞
I am sorry you are having issues with getting your network logs, I can see you have rebooted since your post and we do normally advise a reboot to see if you can get them after this.
How is it looking? Are you able to see your logs?
Zoie
Nigel1971
  • 199
  • 7
  • 9
Up to speed
Message 3 of 10
They have appeared for now, but I bet I’ll get the same issue again.
Sephiroth
  • 22.44K
  • 642
  • 4.01K
Message 4 of 10
The VM bod should have noticed that your downstream SNR is reporting 33/34 dB which is below spec. That said, the Hub is reporting no post-R/S errors (uncorrectable data).
Maybe the VM person can check this out for you. What’s the upstream showing? Also the DOCSIS 3.1 downstream channel (if you’re on 1 Gig)?
Also do please check that your coax cable is tightly screwed in at both ends.
Nigel1971
  • 199
  • 7
  • 9
Up to speed
Message 5 of 10
Did a reboot and the downstream went back to 40db, it’s dropped back to 38db now.
3.0 Upstream channels
12360000038.5205995120 KSym/sec64QAM13
23010000039.5205995120 KSym/sec64QAM12
33660000040.0205995120 KSym/sec64QAM11
44310000040.0205995120 KSym/sec64QAM10
54960000040.5205995120 KSym/sec64QAM9
1US_TYPE_STDMA0030
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
5US_TYPE_STDMA0000
3.1 Upstream channels
1410.035.02KQAM8
14OFDMA20053.900
Sephiroth
  • 22.44K
  • 642
  • 4.01K
Message 6 of 10
According to the stats, you’re problem free.    If the circuit isn’t flapping, then every time you take the stats, you’ll see what you’ve posted.
Performance OK?
Akua_A
  • 4.73K
  • 122
  • 324
Message 7 of 10
Thank you for the update @Nigel1971
As mentioned by @Sephiroth  how has your performance been since posting? I can see you have very recently been in contact with a member of our team regarding a similar issue.
Akua_A
Nigel1971
  • 199
  • 7
  • 9
Up to speed
Message 8 of 10
Seems ok now, don’t know why my monitor is totally red though.
Sephiroth
  • 22.44K
  • 642
  • 4.01K
Message 9 of 10
You've possibly been assigned a new public IP address. Did your hub reboot at any time today?
jem101
  • 4.82K
  • 482
  • 2.13K
Superstar
Message 10 of 10
Snip...
Well if the 'VM bod' as you call them, were in any way 'technical' and actually had any real understanding of how the technology works, then yes, I would have expected them to notice it, but as they aren't then we really can't expect anything too far beyond 'have you turned in off and on again'!
Incidentally, are you as intrigued as I am by the fact that the Hub 4 appears to be able to measure the D/S MER values to six places of decimal? Furthermore, many of the values are identical to the same six places of decimal - which does seem to be stretching credulity somewhat, no?
Bottom line, and I have said this many times before, based on what we are seeing the values as displayed by the Hub 4 absolutely cannot be regarded as accurate - maybe it's just some oddball reporting issue and a bug in the firmware - but on that basis, can we be sure of anything else that the hub is claiming?
