on 31-07-2022 10:25
My VM Hub 4 has decided to stop working overnight. I no longer have Internet connection to my separate WiFi router. I was running the hub 4 in modem mode but now there is no connectivity out of any of the network ports on the back of the unit. I have tried factory reseting the unit but after 1 minute button presses nothing happens. Not even a flashing top light. I have also tried connecting my laptop directly and configuring it again but I don't even get flashing lights on the network port. I have tried and tested the cable.
on 31-07-2022 12:09
Does it work in router mode?
Is the broadband connection okay?
on 31-07-2022 12:34
Annoyingly I can't turn it into router mode since I cant get any access to it.
It looks like the Hub 4 doesn't go through a proper boot up procedure when powering on and it is stuck in a state of limbo. It wont let me reset it using the button and there is no network connectivity at all.
on 02-08-2022 12:51
Hi there @Elijacko1990
Thank yous o much for your first post to our community forums and welcome to the team!
I'm so sorry to hear that this has happened! I can see that you have spoken to our teams and now have an engineer booked.
Are you able to let us know how things are looking after this appointment?
Thanks again.
