josogorm
  • 19
Message 1 of 9
Hub 4 loses settings on reboot
i'm having the exact same problems and tried the 60 sec factory reset and still having the same issue.  I suspect it's a bug in the firmware as the hardware is working well
  • 12.83K
  • 999
  • 2.56K
Message 2 of 9
Re: Hub 4 loses settings on reboot
What settings have you changed?
josogorm
  • 19
Message 3 of 9
I’ve changed the SSID name of both 2.4 & 5. Every time I reboot the router the 2.4 reverts back to its original name. 5 is unaffected.
it definitely looks like a bug in the firmware. Very annoying though to such an extent I’ve now disabled 2.4
  • 12.83K
  • 999
  • 2.56K
Message 4 of 9
Try turning off smart/Intelligent WiFi.
josogorm
  • 19
Message 5 of 9
ok i'll give it a try tonight and see if it makes a difference
josogorm
  • 19
Message 6 of 9
Morning, just to let you know this appeared to work.
Will there be a fix coming as I’m conscious I’m no longer using Smart Wi-Fi which I guess is optimising my network
  • 12.83K
  • 999
  • 2.56K
Message 7 of 9
" I guess is optimising my network" you should be so lucky, only seems to do the reverse. It has to be on if you use the VM pods, otherwise best left off.
josogorm
  • 19
Message 8 of 9
Thanks for clarifying and it will now remain off 😀
many thanks for your help
Smithyg22
Message 9 of 9
Thanks for this thread - I was having the same issue (although I lost the 5GHz setting and the 2.4 remained unaffected). Have switched off smart wifi and seem to be back in business.
