on 30-11-2021 08:06
Hi the hub 4 keeps disconnecting once or twice a week I have looked in the network log and some entries are logged some are not logged at the time the hub went down ?
Get these in the logs lots I will post detailed ones if required thanks.
No Ranging Response received - T3 time-out
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM
CM-STATUS message sent. Event Type Code: 24; Chan ID: 33
Answered! Go to Answer
on 18-12-2021 17:59
Hi Mikeuk
Thanks for coming back to us. I've done a system check and no issues are showing, all levels are in spec and no issues with congestion or SNR (signal to noise ratio). I hope therefore all is sorted. If not, please can you do the following;
Can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a Broadband Quality Monitor. This will monitor the state of your connection and record any network dropouts etc. Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum 🙂
Best,
on 22-12-2021 08:22
https://www.thinkbroadband.com/broadband/monitoring/quality/share/594ecc1b179c8275fe307a1860f5a0649fc876b1-22-12-2021
Hi went off last night
on 22-12-2021 08:41
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
on 22-12-2021 08:41
12 | 227000000 | 5.000000 | 40.366287 | QAM256 | 12 |
6 | 179000000 | 4.699997 | 40.366287 | QAM256 | 6 |
7 | 187000000 | 4.699997 | 40.366287 | QAM256 | 7 |
8 | 195000000 | 4.599998 | 38.983261 | QAM256 | 8 |
9 | 203000000 | 4.599998 | 38.983261 | QAM256 | 9 |
10 | 211000000 | 4.599998 | 38.983261 | QAM256 | 10 |
11 | 219000000 | 4.900002 | 40.366287 | QAM256 | 11 |
13 | 235000000 | 5.400002 | 38.983261 | QAM256 | 13 |
14 | 243000000 | 4.099998 | 38.983261 | QAM256 | 14 |
15 | 251000000 | 4.699997 | 38.983261 | QAM256 | 15 |
16 | 259000000 | 5.000000 | 38.983261 | QAM256 | 16 |
17 | 267000000 | 5.300003 | 38.983261 | QAM256 | 17 |
18 | 275000000 | 6.000000 | 38.983261 | QAM256 | 18 |
19 | 283000000 | 5.400002 | 38.605377 | QAM256 | 19 |
20 | 291000000 | 5.000000 | 38.983261 | QAM256 | 20 |
21 | 299000000 | 4.900002 | 38.605377 | QAM256 | 21 |
22 | 307000000 | 4.599998 | 40.366287 | QAM256 | 22 |
23 | 315000000 | 5.199997 | 38.983261 | QAM256 | 23 |
24 | 323000000 | 5.300003 | 38.983261 | QAM256 | 24 |
25 | 331000000 | 5.099998 | 38.983261 | QAM256 | 25 |
26 | 339000000 | 5.400002 | 40.366287 | QAM256 | 26 |
27 | 347000000 | 4.800003 | 38.983261 | QAM256 | 27 |
28 | 355000000 | 5.099998 | 38.605377 | QAM256 | 28 |
29 | 363000000 | 5.199997 | 38.983261 | QAM256 | 29 |
30 | 371000000 | 4.699997 | 38.983261 | QAM256 | 30 |
31 | 379000000 | 5.199997 | 38.983261 | QAM256 | 31 |
32 | 387000000 | 4.599998 | 38.605377 | QAM256 | 32 |
34 | 395000000 | 4.699997 | 38.983261 | QAM256 | 34 |
35 | 403000000 | 5.199997 | 38.983261 | QAM256 | 35 |
36 | 411000000 | 4.500000 | 38.983261 | QAM256 | 36 |
37 | 419000000 | 5.000000 | 38.983261 | QAM256 | 37 |
12 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
25 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.605377 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
32 | Locked | 38.605377 | 0 | 0 |
34 | Locked | 38.983261 | 0 | 0 |
35 | Locked | 38.983261 | 0 | 0 |
36 | Locked | 38.983261 | 0 | 0 |
37 | Locked | 38.983261 | 0 | 0 |
33 | 96 | 4K | 1880 | QAM4096 | 424 |
33 | Locked | 41 | 5.5 | 181366492 | 0 |
on 22-12-2021 08:42
1 | 60300000 | 45.520599 | 5120 KSym/sec | 64QAM | 1 |
2 | 46200000 | 44.020599 | 5120 KSym/sec | 64QAM | 3 |
3 | 39400000 | 43.520599 | 5120 KSym/sec | 64QAM | 4 |
4 | 53700000 | 45.020599 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 22-12-2021 08:43
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | cmreg-vmdg640-bbt060-b.cm |
SFID | 155956 |
Max Traffic Rate | 230000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 155955 |
Max Traffic Rate | 22000061 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
on 22-12-2021 08:49
Sat Dec 18 07:53:41 2021 | 3 | No Ranging Response received - T3 time-out;CM-;CMTS-4;CM-QOS=1.1;CM-VER=3.1; |
Sat Dec 18 10:33:21 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-;CMTS-4;CM-QOS=1.1;CM-VER=3.1; |
Sat Dec 18 11:00:50 2021 | 3 | No Ranging Response received - T3 time-out;CM-;CMTS-4;CM-QOS=1.1;CM-VER=3.1; |
Tue Dec 21 07:10:21 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-;CMTS-4;CM-QOS=1.1;CM-VER=3.1; |
on 24-12-2021 09:44
Hi Mikeuk
Thanks for getting back to us and welcome back.
I've took a look into the account and there's nothing on there at the moment that would directly contribute to the disconnections you have raised with regards to power levels and router stats.
I can see this it has disconnected twice this week via SamKnows on Tuesday and Wednesday, can I ask whether it's affecting only wireless devices or wired?
on 24-12-2021 10:51
Hi thanks its both
on 27-12-2021 09:40
Hi Mikeuk
Everything is looking perfect here
The only option we have is to book a tech and look at swapping the hub
Let me know if you wish to go down that route
Gareth_L
