on 10-06-2022 19:05
on 10-06-2022 19:15
You seem to have done most debugging actions I can think of, although one last one is to temporarily turn off the WiFi on the hub and see if the V6 will connect. Only other suggestion is to get an 8 or 16 port Ethernet switch and run all Ethernet connections through that.
on 13-06-2022 12:27
Hi Kwashi,
Thank you for your post and welcome to the forums 🙂
I am sorry to hear you are having issues with your ethernet/wifi.
Have you tried @Tudor's advice? Did this help?
I have checked our systems and all looks fine, it just advises your 5.0Ghz is at capacity, please let us know if you need any more assistance.
Zoie
