on 29-10-2021 11:47
I installed our new Hub 4 yesterday and everything is working well. I want to change the password though so opened up http://192.168.0.1/ as instructed but it says I'm entering the wrong password (which is on the card). Have tried multiple times.
I know you can't do it through the app, I am using a browser.
Any ideas?
Answered! Go to Answer
29-10-2021 13:45 - edited 29-10-2021 13:46
It sounds like you are inputting the wifi password instead of the Settings password (8 numeric digits)
EDIT
The settings password should be on the base of the hub.
EDIT
on 29-10-2021 14:23
You are right, thank you so much!
I was only wanting to change the password for logging into the wi-fi! All done now.
on 29-10-2021 14:27
Hi again @vickigilmore
Thanks for the update,
It's good to see you managed to change your logging in password.
Stay safe and take care.
