  • 6
Message 1 of 7
Hub 4 and smart plug problem
Recieved my Hub 4 and connected  it ..... now have issues ,which are I cannot connect my smart plugs .There was no issues when I had my Hub 3....they worked fine. Any one else had  problems such as mine ?
  • 24.4K
  • 1.4K
  • 3.1K
Message 2 of 7
Re: Hub 4 and smart plug problem
What plugs are they? I’m guessing they work in the 2.4Ghz band only.
Have you changed the WiFi name and password to that of the old hub?
If not have you factory reset the smart plugs to set them up again from fresh with the new network settings?
  • 6
Message 3 of 7
Yes 2.4ghz smart plugs. (As they will not work on 5ghz).
Yes changed wifi name and password onto Hub4 as per the Hub3.
Yes done reset on smart plugs and tried manual and auto scan setup on smart life app....but no joy.
  • 24.4K
  • 1.4K
  • 3.1K
Message 4 of 7
Disable the 5Ghz band broadcast on the hub so that 2.4Ghz only is broadcasting.
Setup and add the plugs then enable the 5Ghz band again after.
  • 6
Message 5 of 7
Yes tried that also....no joy.
Message 6 of 7
Can I add a me too to this post.
Disabled 5Ghz but had no luck, but they do work at my parents (BT connected) house.
  • 11.49K
  • 891
  • 1.46K
Message 7 of 7
@Senscall wrote:
... snip ...
If you want assistance please start your own thread.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
